Archived from groups: alt.comp.periphs.videocards.nvidia (
More info?)
well, it was a driver problem. what happened was that I failed to
remeove the old nvidia drivers before installing the new one. that
screwed thing up.
it is fixed now.
thanx anyway for your help.
stevem wrote:
>Exactly as you would in normal running, i.e right-click on an empty area on
>the desk-top, select properties, then settings, then slide the slider to get
>to 1280x1024, then apply. This is XP, but from memory 98SE is identical.
>Best wishes
>Steve
>"Dilbert Firestorm" <scanb_no_spam31@*no_spam*I-55*no_spam*.com> wrote in
>message news:cvtj6t$4go$1@news.datasync.com...
>>how do you reset the resolution in safe mode?
>>stevem wrote:
>>>Have you tried going into Safe Mode to reset the resolution? Usually, that
>>>will work fine.
>>>message news:cvt9g2$qf$1@news.datasync.com...
>>>>do you know which drivers are for the gf4mx420 at the nvidia site?
>>>>dawg wrote:
>>>>>Maybe it's the refresh rate. St it to default.Try safe mode if you need
>>>>>to.
>>>>>in
>>>>>message news:cvq1iv$jpp$1@news.datasync.com...
>>>>>>my windows machine has a win98se, nvidia Geforce 4 mx400. I just
>>>>>>recently purchased a 19" planar PL1910M lcd monitor. I am having
>>>>>>trouble setting the resolution on the windows machine. the resolution
>>>>>>was originally set for an old 17" viewsonic vg175 lcd monitor. the
>>>>>>screen goes black after reboot when the resolution is set at 1024X768.
>>>>>>I am trying to get it set at 1280X1024 resolution.
