Tom's Hardware > Forum > Systems > Gateway2000 > No sound on Gateway G6-400 mini tower
Forum Systems : Gateway2000 - No sound on Gateway G6-400 mini tower
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Hi,
Recently inherited a Gateway G6-400 minitower (circa 1998). The
computer does not play sound. I have tried installing speakers
without success. Looking at hardware profile I can see PC MultiMedia
Audio Device listed which I assume is sound card but it says that
drivers are not installed (code 28).
If is is the drivers causing problem I need to know which drivers I
need and how to get them. I am running Win98 2nd ed. but am about to
upgarde to XP.
Any advice?
Thanks.
Sponsored Links
Check the card it's self to get the manufacture, model, and serial #.
Also take note of the chipset as some cards are the same make and model, but
with different chipsets and require different drivers. Then go to the
manufacturers website to get their latest drivers for your operating system.
You can also check Gateways sound card page at:
http://support.gateway.com/support [...] t_sou.html
KC
"mbarton" <mattpb@gmail-dot-com.no-spam.invalid> wrote in message
news:428b43dc$1_5@alt.athenanews.com...
> Hi,
> upgarde to XP.
> Any advice?
> Thanks.
Reply to Anonymous
Try your upgrade to xp first. It may have the drivers you need - I upgraded
a G6-400 and had no sound card problems (i.e. didn't need special drivers).
"Kevin Childers" <wildthing123@charter.net> wrote in message
news:17Iie.2280$eR.1062@fe05.lga...
> but
> system.
> KC
>> Hi,
>> upgarde to XP.
>> Any advice?
>> Thanks.
Reply to Anonymous
"Tom Clydesdale" <t.clydesdale.nospam@comcast.net> wrote in message
news:bqSdnSbUh9FZyRbfRVn-uQ@comcast.com...
upgraded
drivers).
> > but
> > system.
> > KC
> >> Hi,
> >> upgarde to XP.
> >> Any advice?
> >> Thanks.
Same here. Have a Creative Sound Blaster Live 5.1 card in a Gateway G6-350
Win98SE with no drivers but when I upgraded to WinXP Pro the drivers were
installed during setup. HTH
Louie
Gainesville, FL, USA
Reply to Anonymous
Or is the sound chip integrated into the motherboard? ... Ben Myers
On , "Kevin Childers" <wildthing123@charter.net> wrote:
>NNTP-Posting-Date: Wed, 18 May 2005 07:16:29 MST
>Date: Wed, 18 May 2005 09:16:11 -0500
>Xref: Hurricane-Charley alt.sys.pc-clone.gateway2000:4946
>X-Received-Date: Wed, 18 May 2005 07:16:29 MST (be02_lga)
>http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt_sou.html
>KC
>> Hi,
>> upgarde to XP.
>> Any advice?
>> Thanks.
Reply to Anonymous
There are 1001 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
