G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi all,
I removed the stock GPU cooler and ramsinks on my PNY 6600GT and put in
a Zalman VF700-AlCu instead. The results were immediately obvious from
the reduction in noise compared to the stock cooler, and also in the GPU
core temp readings while running a D3D animation. Previously, I had
noted temps like 85 C in the control panel on load, and about 60 C idle.
Now I get 42 C idle and between 55 and 58 C on load, with no OC. I
bumped up the GPU core to 520 MHz and the memory to 1.04 GHz (double),
and there was only a 2 C rise in temp
Can someone give me hints on how high I can go with this setup? Thanks.
One more thing, the PNY stock RAM coolers had more metal in them than
the Zalman ones, but were too tall to use along with the GPU cooler.
Then again, the main benefit of more metal in a heatsink is to give it
thermal inertia. Since the RAM chips don't change temp suddenly, this
should not be such a big deal.
I also noted down the markings on the memory chips, these are 2.0 ns
versions (not 1.6), so the memory overclocking abilities of the PNY
6600GT may not be so good.
-Jim
Hi all,
-Jim
