G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi... I need some suggestions from anyone who's encountered trouble
installing a 6600gt, or anyone who knows the operational details of the
NVIDIA Sentinel.
I have an AOpen Aeolus 6600gt AGP that I'm trying to run on an older system.
The problem is that when Windows starts, I get a message saying that the
NVidia Sentinel has detected insufficient power, and that the card is being
powered down for its own protection.
When I first saw this, I thought that perhaps my power supply was
insufficient, so I tried changing the molex connector. No difference. I
had an extra PSU kicking around, so I've currently got that running
everything but the motherboard and the graphics card, which are the only
things now on my 300W PSU. I still get the same error message, even with
18A available on the +12 V rail.
I've picked up all the latest motherboard drivers, chipset drivers,
Forceware 71.84, etc., but that hasn't made a difference. I've checked the
temperature, and it's running a consistent 40 or 41 C. I tried disabling
fast writes. I've unplugged and replugged both the molex connector and the
card about a hundred times.
I got worried that perhaps the card was bad, so I took the card to another,
newer machine, and plugged it in. It worked perfectly, the first time, with
no power warnings (and all features enabled).
I have read reports on the Internet about people with similar systems to
mine getting a 6600gt going, and I was wondering if anyone out there has any
suggestions. I've also heard things about the 6600gt reacting negatively to
the 761 Northbridge on some AMD boards, but I haven't picked up any
specifics of the problems. In addition, I'm using WinME on this machine
(the machine it worked on was XP64), and the Aeolus is, according to the
box, just for WinXP/2000, so perhaps that is causing problems, although I'd
suspect that the NVIDIA Sentinel would be solely a hardware thing, and
independent of OS. On the other hand, I have the card operating. There are
no problems with artifacts, or reboots, or anything like that. It's just
not picking up on the fact that I've got it plugged in, so I don't get neat
stuff like an operational pixel shader.
My specs are:
1.4 GHz Athlon Tbird
Gigabyte GA-7DXR mobo
256 MB RAM
hard drive, dvd, cd, etc.... all that's being powered on the other PSU.
Windows ME
All I can think of is that it's a PSU connection problem (except that it
worked immediately on the other system), or it's an OS conflict with the
NVIDIA Sentinel thing, or perhaps I can't use the NVIDIA-supplied drivers
and must rely on the ones supplied by AOpen (which would be really weird).
Any suggestions are greatly appreciated, and any that help will be rewarded
with limericks or something.
Thanks,
Glen
NVIDIA Sentinel.
My specs are:
256 MB RAM
Windows ME
Thanks,
Glen
