Tom's Hardware > Forum > Graphic & Displays > Nvidia > Palit GeForce4 MX440 & Princeton LCD1700 problem
Forum Graphic & Displays : Nvidia - Palit GeForce4 MX440 & Princeton LCD1700 problem
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
In the BIOS/VESA mode of 720x400, the card is at a 69hz refresh rate (??)
vs. standard of 70hz. At this resolution, the only compatable rate is 70hz.
Thus, I cannot get into the system BIOS to check anything (due to a
scrambled screen). Is there any updated BIOS that I can flash or if I
connect a CRT can I change it? In WinXP, full screen command prompt windows
have the same problems.
Thanks!
Hardware:
Palit GF4 MX440 8X 64MB DDR 64bit TV-out AGP
Princeton LCD 1700
Sponsored Links
> Thanks!
> Hardware:
> Princeton LCD 1700
I don't know if there's much that can be done about that with this
combination.. must be an awfully picky monitor if it's unable to display
if the refresh rate is 1 Hz off..
Robert Hancock Saskatoon, SK, Canada
To email, remove "nospam" from hancockr@nospamshaw.ca
Home Page: http://www.roberthancock.com/
Reply to Anonymous
There are 1285 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
