Fan speed during POST
Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
Has anybody seen the following effect?
When the system boots up, the fan speed of my BFG 6800 OC is high and it
slows down when windows boots up and I get the Login screen (noticable with
the sudden decrease in noise).
Whats causing this sudden slow down??
7 answers Last reply
More about speed post
  1. Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
    It's probably normal. I'm sure it's variable depending on gpu temp. Try an
    intense 3D game and the fan speed will likely increase.
    DaveL
    "Kiran Kumar Kamineni" <kkumar@hp.com> wrote in message
    news:gBv2e.2504$N7.1982@news.cpqcorp.net...
    > with the sudden decrease in noise).
  2. Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
    On Wed, 30 Mar 2005 10:56:12 GMT, "Kiran Kumar Kamineni"
    I get that too.
    I always assumed it was a power supply sag caused by the vid card
    going into "performance" mode. It seems as if *all* of my fans slow
    down once the vid card starts pulling extra juice, but maybe it is
    just the vid card fan... hard to tell with fan noise. It happens as
    soon as the GUI appears on boot. At first I thought it was a power
    supply problem, but it happens with two different high-quality power
    supplies.
    My vid card (eVGA 6800 GT) doesn't advertise any special fan control
    capability, and there's no background software or service running that
    would cause the slowdown of the fan. It slows down once the GUI
    appears, and speeds up during the boot process. The fan speed never
    changes during intense 3D activity. Only at boot.
  3. Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
    Have a gander at this
    http://www.xbitlabs.com/articles/video/display/gainward-ultra2400_4.html
    different card but you get the idea, once your settings kick in for the
    forceware drivers the fan slows down.
  4. Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
    "Folk" <Folk@folk.com> wrote in message
    news:aonl41phqsglmovsd2jt497aagl8ui9maj@4ax.com...
    with
    > I get that too.
    > supplies.
    Same here. I couldn't figure it out for a while as I had never heard it
    before, but, I had a new power supply with a variable speed fan installed
    whereas before it was a single speed fan. Immediately prior to the fan
    slowing down I hear six clicks which I had thought was drive heads so
    thought the sound of something slowing down was to do with a drive, but, a
    mate told me the PS fan runs at full speed up to a certain point in the boot
    sequence. I had never thought it was when the GUI appeared, learn something
    every day.
    Rob
  5. Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
    Likely it defaults to high speed on bootup as a fail-safe but when the
    driver loads it reduces the fan speed..
    Robert Hancock Saskatoon, SK, Canada
    To email, remove "nospam" from hancockr@nospamshaw.ca
    Home Page: http://www.roberthancock.com/
  6. Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
    The fan speed is driver controlled therefore the fan runs at maximum speed
    until the driver initialises and takes control.
    "Robert Hancock" <hancockr@nospamshaw.ca> wrote in message
    news:xjL2e.858824$8l.475305@pd7tw1no...
  7. Archived from groups: alt.comp.periphs.videocards.nvidia,alt.comp.periphs.videocards.ati (More info?)
    On Fri, 01 Apr 2005 06:25:52 GMT, "Matthew Wheeler"
    If the fan speed is driver controlled, why doesn't the fan speed
    change once the driver initializes? My 6800 GT *never* changes fan
    speed once I've booted into the OS, no matter how much I punish it
    during heavy 3D processing. There are only a few high-end cards that
    advertise the capability to alter fan speed, and those are the ones
    with those big-assed fans that take up two slots.
    So why would it slow down when it boots to the OS and then stay that
    way until you reboot, regardless of the onboard temps? Doesn't make
    sense.
Nvidia Fan Speed Graphics
