Archived from groups: alt.comp.periphs.videocards.nvidia (
More info?)
Oops. You are in the United Kingdom.
"GG" <nospam@charter.net> wrote in message news:R503e.72$yL2.22@fe08.lga...
> Neil,
> Thanks so much!
> I just left my Dad's house and what you told me fixed the problem.
> Now, I've got another quesiton.
> The screen is not positioned correctly.
> I tried the following and it worked but once the pc is rebooted it goes
> back the way it was before.
> I go to screen adjustment and use the right arrow until the screen is
> correct.
> I click apply then ok.
> I even tried save the default profile.
> What am I missing this time?
> I'm assuming by your website that you are in the UK?
> Thanks again for your help.
> My Dad was tickled pink!
> "Neil J Bundy" <nospam_bubbleman@neil-bundy.demon.co.uk> wrote in message
> news:XZ9$PlCC9ySCFwgq@lon1-aj2a.demonadsl.co.uk...
>> Try the following - it works on my normal flat panel believe it or not!
>> Make sure the projector is your current display.
>> Go to Control Panel -> Display Properties, click on "Settings" Tab, then
>> "Advanced" button, and choose the "GeForce 660GT" Tab. Highlight "Screen
>> resolutions & Refresh Rates".
>> You will see there is a section on this page for Custom Resolutions &
>> Refresh Rates. Add the resolution you need for your projector 1440x960 at
>> the appropriate refresh rate. You have to accept a disclaimer about using
>> custom rates - be sure to read it so you understand just in case!
>> Then click the "Only show custom modes" tickbox and apply your new
>> refresh rate.
>> Good luck - hope this solves your problem.
>> Neil.
>> In message <AIF2e.1719$Ns7.1704@fe07.lga>, GG <nospam@charter.net> writes
>>>I've checked the newgroup and was unable to find this answer.
>>>How in the world do I get 1440x960 to stay with a crt projector?
>>>(Using the vga port by the way)
>>>I tried Nvidia's display control panel and powerstrip.
>>>When using Nvidia's control panel, the pc will only go back to 1440x576.
>>>Right now it's set at 1280x1024.
>>>Is anyone using a Nvidia 6600GT agp card set at 1440x960?
>>>If so, can you please give me step by step instructions on how to make
>>>these
>>>settings stay?
>>>The crt projector is an Electrome 9500.
>>>I'm also using the latest version Nvidia driver, 71.84.
>>>The pc is Windows xp with sp2.
>>>Motherboard, Asus P4C800E Deluxe and Intel 3.2
>>>(Oh yeah, this is my Dad's pc so I won't be able to try anymore stuff
>>>until
>>>I'm back at his place)
>>>Does anyone know the correct timing settings, horizontal and vertical
>>>settings, back porch, front porch, etc.?
>>>These are the instructions that I used from Nvidia and powerstrip.
>>>I didn't have any luck with the instructions by the way.
http://nvidia.custhelp.com/cgi-bin/nvidia.cfg/php/endus...
>>>hp?p_faqid=36&p_created=1096923831&p_sid=hxEocCBh&p_lva=&p_sp=cF9zcmNoPS
>>>ZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0yMTAmcF9wYWdlPTE*&p_li
>>>and
http://www.entechtaiwan.net/forums/viewtopic.php?t=24
>> Neil J Bundy
