Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Trouble Establishing Wireless Connection
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
After several months of successful access to my residential gateway [RG]
from a built-in wireless network adapter in my IBM T41 ThinkPad a problem
has suddenly developed whereby I am unable to access the RG; I am able to
access it from a second machine that I have ... also with a wireless network
adapter. Now when I single click the icon in the task bar for the wireless
connection on the failing machine the Wireless Network Connection Status
window comes up and when I click on the Support tab the TCP/IP settings I
see are all wrong. The Address Type is "Automatic Private Address" ... the
IP address is "169.xxx.yyy.zzz" [the xxxx, yyy and zzz values are valid but
I prefer not to display them here ... the Subnet Mask is 255.255.0.0 and the
Default Gateway is blank. These values are not correct ... but I don't
know how to fix them. On my other (non-failing) machine these values are
"Assigned by DHCP" ... 192.168.1.6 ... 255.255.255.0 and 192.168.1.1
respectively. I have run hardware diagnostics on the wireless adapter in
the failing machine [it is an Intel PRO/Wireless LAN 2100 3B Mini PCI
Adapter] and all tests passed. Can someone suggest what properties/settings
I should set that will correct these values? As near as I can see I have
things set properly ... eg. Obtain an IP Address Automatically is selected,
as is Obtain DNS Address Automatically.
I am beginning to think that although the hardware diagnostics did not show
a problem that indeed there IS a problem with the wireless adapter.
Thanks for whatever assistance may be forthcoming.
Sponsored Links
There are 619 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
