Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Viewsonic PF790 Help
Forum Computer Peripherals : CRT Monitors - Viewsonic PF790 Help
I just got my viewsonic pf790 in today and setup it all up. Most things seem fine except that it seems a little bit out of focus and the righthand corners are a little messed. Does anyone have the same monitor? What settings are you using to correct these problems. I cant seem to get them exactly perfect. Also what should my contrast be set at? Should it be all the way at 100? Right now my brightness is at 75.
Thanks in advance.
Sponsored Links
I just got this monitor not too long ago. Are your speakers near the screen? If so the magnents in them will mess up your display. Also put the settings to the default to get things looking right, that is what I have realized looks the best.
Reply to Anonymous
There are 1153 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
