Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hello,
I have had a BFG 6800GT for a couple of months now and it has been
running perfectly at full, maximum screen settings (2048x1536x32).
in BFV.
Yesterday, after less than 1 hours play, it crashed to a "crazy
paving" type screen and then the monitor went to "no signal". Reboot
did nothing, but the sytem came back up after switch off and on.
This scenario now keps reoccurring after 30 - 45 minutes of play. The
PC runs fine for protracted periods (hours) outside of gameplay.
The card is not run overclocked.
Suggestions as to the problem- is it likely to be temperature ? What
software can I use to monitor the cards temp? Solutions?
Thanks for any help.
Regards.
Hello,
in BFV.
Regards.
