Archived from groups: alt.comp.periphs.videocards.ati,alt.comp.periphs.videocards.nvidia (More info?)
need to know if i am able to fit the following card into standard size pc
case (not low profile)
http://www.cdw.com/shop/products/default.aspx?EDC=329522
it says that it comes with LT bracket. Does it mean i can use pliers to take
it off and then
put new one on it.
Also will i be able to connect it to 2 monitors with VGA adapters.
thank you very much
it off and then
put new one on it.
thank you very much
