For approximately the past two months, I've noticed that my sound, system-wide, has begun to stutter. It appears to be a performance-related issue, because the sound stutters more violently during the system startup sound and when I've got the computer doing computationally-intensive tasks. I've had this Windows 7 (Professional, x64) install for just over a year now, and up until these last two months, there was no stuttering whatsoever.
My hardware configuration, aside from my power supply and system fan, is no different from that which I installed Windows on. I'm currently not overclocking anything, and the only minor hardware-related change my system has seen are bios updates for my Gigabyte G41M-ES2L motherboard. I'm using my motherboard's built-in Realtek ALC888B audio, using Gigabyte's motherboard-specific driver.
I've done full scans/cleanings using up-to-date versions of Microsoft Security Essentials (which I do weekly scans with), Malwarebytes, Spybot and CCleaner, none of which have resolved or even reduced my issue. My Windows install and major programs are all up-to-date. While my Windows install is by no means spartan, it is well-maintained, and I'm using just over half of the space in my 320GB hard drive. HWMonitor reports 36 Celsius CPU core temps, and a 56 Celsius GPU temp. I clean the insides of my case fairly regularly, so I doubt this is a cooling issue.
I suspect winrot, but I'm open to any suggestions. I can provide further system information, if necessary.
