Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi, I have been lurking here for a while (whilst awaiting the delivery of my
wireless adapters) and I have taken note of many good links and advice
(Thanks guys)
However, I just can not get it to work properly and I am almost at the point
of launching the computers through the window.
Here is the spec.
Origo ADSL router ASR 8400 (4 port wired)
Desktop PC Windows XP pro SP1 Norton Internet security 2004
Laptop PC Windows XP pro SP1 Norton personal firewall 2003
Both connected to the router *wired* with router assigned IP addresses and
using the ORIGO Ethernet setup program
IP Desktop 10.0.0.7 Laptop 10.0.0.4 Subnet mask 255.0.0.0 gateway 10.0.0.2
(these work fine if I input them and set the Router to not assign the IP
addresses as well.)
All works fine, file sharing, printer sharing and both connect to the net
using the router. (Can not view workgroup computers though, and need to
search for the computer name to connect - Then is available in "My Network
Places" )
When trying to view workgroup computers I get this message:
"MSHOME is not accessible. You might not have permission to access this
resource. Contact the system administrator to find out if you have
permissions. The list of servers for this workgroup is not currently
available."
I have disabled simple network sharing, enabled guest with a password but
the computers will not allow me to access the workgroup. This is a pain, but
not the point of the post.
Wireless configuration:
Same computers, cat5 cable removed from laptop.
Desktop has a ZyDas ZD1201 wireless USB adapter and is connected to the
ORIGO router using Cat5
Laptop has a Level One 11Mbps 32bit Wireless PCMCIA adapter
I followed the tutorial on
http://www.microsoft.com/windowsxp [...] pril08.asp
and the wireless cards see the SSID and seem to connect. When hovering over
the connection icon in the start bar I get a message Wireless Network
Connection (Peer to Peer) Speed:11Mbps Signal Strength: Excellent.
I ran the internet sharing wizard and rebooted.
Desktop connected to Router Via cable Works fine on the Internet, No file
sharing, no printer sharing
Laptop - Nothing. No file sharing, no printer sharing, Can not Ping the
other computer, no Internet.
Bugger.
I have spent all day on this and I am very fed up.
Could some kind soul out there please tell me the error of my ways and how
to fix it?
I have networked many peer to peer computers using Win 95/98 and cat5/hubs
etc (suites of 20+computers). I am quite new to Windows XP.
Cheers
-halli-
> delivery of my wireless adapters) and I have taken note of many good
> links and advice (Thanks guys)
> the point of launching the computers through the window.
> Here is the spec.
> addresses and using the ORIGO Ethernet setup program
> 10.0.0.2 (these work fine if I input them and set the Router to not
> assign the IP addresses as well.)
> net using the router. (Can not view workgroup computers though, and
> need to search for the computer name to connect - Then is available
> in "My Network Places" )
> this resource. Contact the system administrator to find out if you
> have permissions. The list of servers for this workgroup is not
> currently available."
> but the computers will not allow me to access the workgroup. This is
> a pain, but not the point of the post.
> the ORIGO router using Cat5
> hovering over the connection icon in the start bar I get a message
> Wireless Network Connection (Peer to Peer) Speed:11Mbps Signal
> the other computer, no Internet.
> Bugger.
> and how to fix it?
> cat5/hubs etc (suites of 20+computers). I am quite new to Windows XP.
> Cheers
> -halli-
Need more information from one of the problem wireless adapters.
From a command prompt, type:
ipconfig[space]/all[space]>C:\iplog.txt[enter]. Open the file
C:\iplog.txt, copy the entire file and paste back to this thread.
[space] is a blank space.
Q
You have bridged the connections??
http://support.microsoft.com/defau [...] duct=winxp
On Sat, 17 Apr 2004 00:41:46 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
Barb Bowman
Expert Zone Columnist
http://www.microsoft.com/windowsxp/expertzone
MS-MVP (Windows)
> Q
Windows IP Configuration
Host Name . . . . . . . . . . . . : 1xp1800
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : SiS 900 PCI Fast Ethernet
Adapter
Physical Address. . . . . . . . . : 00-0A-E6-15-32-2D
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 10.0.0.8
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Default Gateway . . . . . . . . . : 10.0.0.2
DHCP Server . . . . . . . . . . . : 10.0.0.2
DNS Servers . . . . . . . . . . . : 10.0.0.2
Lease Obtained. . . . . . . . . . : 17 April 2004 19:24:36
Lease Expires . . . . . . . . . . : 18 April 2004 19:24:36
Ethernet adapter Network Bridge (Network Bridge) 11:
Description . . . . . . . . . . . : MAC Bridge Miniport
Physical Address. . . . . . . . . : 02-02-72-04-EF-D9
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
And on the Laptop:
Host Name . . . . . . . . . . . . : LAPTOP1
Node Type . . . . . . . . . . . . : mixed
IP Routing Enabled. . . . . . . . : no
Ethernet adapter Local Area Configuration:
Media state ............. : Media Disconnected
Description .............. : Intel (R) PRO/100 VE Network connection
Physical address ............. : 00-00-F0-84-91-2C
Ethernet adapter Network Bridge (Network bridge) 7 :
Physical Address. . . . . . . . . : 12-E9-43-FE-00_68
IP Address. . . . . . . . . . . . : 192.168.0.2
Default Gateway . . . . . . . . . : 192.168.0.1
I have followed the advice from Barb Bowman in this thread regarding
enabling the NIC on the bridge. Bridge is the firewire port and the wireless
adapter on each machine.
I have tried setting the IP on the bridge as 10.0.0.* for both machines
(where * is a different number on each machine)
I have tried disabling the ethernet adapter and firewire on each machine and
only used the wireless adapters without internet connection/sharing
I have tried disabling Norton.
I am yet to try throwing the PCs across the room.
Help!
-halli-
"Barb Bowman [MVP-Windows]" <barb@nospam.com> wrote in message
news:b54280lforucfvnunnald69h23mp9rvtq3@4ax.com...
Have tried bridging the firewire and wireless and now done the above, they
were disabled. However - nothing! They are still connected, just no way to
share anything.
(where * is a different number on each machine) and tried leaving it as
192.168.0.* as suggested/forced by the wizard.
-halli-
you should unbridge everything at this point. then disable the
firewire. then bridge the wired Ethernet and the wireless if you want
the machine that is totally wireless to have Internet access through
the desktop. for now you should disable all firewalls on the desktop.
On Sat, 17 Apr 2004 20:08:06 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
>http://support.microsoft.com/default.aspx?scid=kb;en-us;302348&Product=winxp
>share anything.
>-halli-
Barb Bowman
MS-MVP (Windows)
news:gl2380t5rt8v70qeikn6kcepmog0fjcrra@4ax.com...
Ok, I have unbridged both computers, disabled firewire on both machines,
Bridged the ethernet card that connects to the router with the USB WLAN
dongle thing and used the ORIGO ethernet setup to configure the connection
from the bridge to the router.
I have set an IP and Subnet mask similar to the bridge on the main PC on the
wireless PCMCIA card on the Laptop. Rebooted the machines and .... Nothing
except connected with speed of 11mbsp and signal strength Very good ... Oh
no, Excellent now!
No windows firewall in place but Norton in place. However, Norton did not
get in the way of ethernet connection or firewire connection 15 mins ago for
file sharing.
-halli-
I don't know what the Origo ethernet setup is, but can you please
(from both computers) start, run, cmd[ok]
ipconfig/all [enter]
copy everything to the clipboard and paste into a reply here
also, for now, please disable the Norton firewall on both computers.
On Sat, 17 Apr 2004 21:32:59 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
>no, Excellent now!
>file sharing.
>-halli-
Barb Bowman
MS-MVP (Windows)
news:j89380tmc89kda62dl8kbeo5rqugcj6rnc@4ax.com...
If it is not run, the router does not speak to the computer and sulks. The
program asks you to choose the ethernet connector (in this case the bridge)
and confirms it is connected. It then reboots the PC and all is well!
but can you please
Here is the latest one!
MainPC
IP Routing Enabled. . . . . . . . : No
Ethernet adapter Network Bridge (Network Bridge) 13:
Physical Address. . . . . . . . . : 02-0A-E6-15-32-2D
IP Address. . . . . . . . . . . . : 10.0.0.10
Lease Obtained. . . . . . . . . . : 17 April 2004 21:20:05
Lease Expires . . . . . . . . . . : 18 April 2004 21:20:05
LaptopPC
Host Name . . . . . . . . . . . . : Laptop1
Node Type . . . . . . . . . . . . : Mixed
Ethernet adapter Wireless Network Connection 2:
Description . . . . . . . . . . . : Realtech RTL8181 wireless LAN
(mini-) PCI NIC
Physical Address. . . . . . . . . : 00-50-fc-d0-73-72
IP Address. . . . . . . . . . . . : 10.0.0.5
Default Gateway . . . . . . . . . : 10.0.0.10
Will do!
Thanks for this help
-halli-
"-halli-" <jwhalli123@yahoo.co.uk> wrote in message
news:c5s9dq$4rtmg$1@ID-112192.news.uni-berlin.de...
> Will do!
Progress! I had been disabling norton from the task bar. I decided to go
into options, check manual instead of at startup and rebooted both machines.
I can now see the Laptop in the view workgroup, but when I double click it I
get a "Network path not found" error. I can not see the desktop from the
laptop.
Internet works on the main PC connected to the router, not on the Laptop.
What am I missing?
-halli-
did yu run the command in the KB article?
On Sat, 17 Apr 2004 23:29:20 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
>> Will do!
>laptop.
>What am I missing?
>-halli-
Barb Bowman
MS-MVP (Windows)
news:3ak480pn95pbnkq3ktc0mlc7d9urc0v8f5@4ax.com...
Do you mean the netsh bridge show adapter command?
These are the results after enabling
ID AdapterFriendlyName ForceCompatibilityMode
1 Wireless Network Connection 4 enabled
2 Local Area Connection disabled
This is the result of this morning's ping from the desktop pc:
Pinging 10.0.0.5 with 32 bytes of data:
Destination host unreachable.
Ping statistics for 10.0.0.5:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The laptop can not ping anything.
Also, the laptop PCMCIA connection keeps revertimng back to Encryption:
Enabled (when clicking on the connection in "Network Connections" and
looking in the Details tab.
Thanks
-halli-
on the host computer, disable the bridge.delete the preferred wireless
connecion. disable norton. reboot. disable everything except the
ethernet and the wireless. setup the ad hoc network. go to the network
connection window and make sure both ethernet and wireless are enabled
and bridge those connections. run the netsh command where necessary.
On Sun, 18 Apr 2004 11:13:12 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
>Thanks
>-halli-
Barb Bowman
MS-MVP (Windows)
news:k7l4809gf80g7fr08nftduqmku6v2jn2nv@4ax.com...
OK, have done all of that now and nothing. :-( I have even lost the laptop
in the workgroup on the Host computer.
Did you mean disable the bridge or delete it? I disabled and then enabled.
Should I try deleting the bridge and re bridging?
Also, the Laptop (client) is still showing Encryption: Enabled in the
details pane of the Network connections, even when I disable WEP.
Does there need to be a bridge on the client computer? The ethernet port is
separate and connects to the router perfectly when enabled and wireless
unplugged. I did have a bridge on the client and did the netsh thing to
enable etc.
Any more ideas please?
-halli-
yes. unbridge/delete ALL bridges when you start over. you only need
the bridge on the desktop between the wireless and the ethernet. i
would remove the ad hoc connection from preferred networks. don't run
that origo utility on anything. just get the desktop and laptop on the
same ad hoc network so that they can see each other. if the origo
device is handing out addresses via DHCP you should not need to do
anything.
On Sun, 18 Apr 2004 14:34:44 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
>enable etc.
>-halli-
Barb Bowman
MS-MVP (Windows)
news:4125809invui9hgnefp6ijn3amakm2uei6@4ax.com...
> anything.
OK, I deleted the bridge, uninstalled both wireless adapters and associated
third party software (which was not being use anyway as Windows was managing
the connection) unplugged the USB adapter and rebooted. I then installed
the adapters from scratch and left out the third party software.
I set up the Ad Hoc as per your tutorial, enabling the bridge and netsh'ing
as appropriate.
set the IP on the client machine (Laptop) to match the assigned address on
the Host machine with the default gateway being the IP of the Host.
Rebooted them both again for good measure and .... It is the same. Wireless
connection is there with excellent signal strength, but no other computers
in either workgroup and pings result in a request time out.
Norton is disabled. Should I uninstall it to see if it is the problem?
Any other ideas?
I am very grateful for this help.
-halli-
Yes, you could try uninstalling Norton. I'm not sure what you mean by
Bit I think you should stop assigning addresses to the wireless
adapters and remove the statics.
go back to the beginning, no bridges, etc.and just let automatic
addressing kick in for each of the wireless adapters. ignore the
Internet for now. also, I'm going to send you to a different online
tutorial to see if that helps you more:
http://www.practicallynetworked.co [...] bridge.htm
On Sun, 18 Apr 2004 16:28:40 +0100, "-halli-" <jwhalli123@yahoo.co.uk>
>> anything.
>as appropriate.
>Any other ideas?
>-halli-
Barb Bowman
MS-MVP (Windows)
news:juh580l68shkot12a66h141nrpc7ld3mga@4ax.com...
on
OK, have done that (you did mean on both machines?) Host adapter has IP of
169.254.53.237 adn a Subnet mask of 255.255.0.0 and the client now has
169.254.115.145 with the same subnet mask.
They still do not appear in each other's workgroup (and Norton in now
uninstalled on both machines!)
Will try this now.
Thanks again
-halli-
----- Original Message -----
Newsgroups: microsoft.public.windows.networking.wireless
Sent: Sunday, April 18, 2004 4:28 PM
Subject: Re: Wired LAN works, Wireless on same machines does not.
(longish
post)
run
the
> > anything.
associated
managing
installed
netsh'ing
> as appropriate.
address on
Wireless
computers
problem?
> Any other ideas?
> -halli-
OK, now I am very cheesed off! For a start I thought I sent this to the
newsgroup - and I replied to me! This is really getting to me now! :-(
I installed the Zydas USB dongle on an old Win 98SE machine .. and it
works
wonderfully with the PCMCIA on the Laptop. Shares files like a nice boy
both
ways (xp - 98SE and vice versa) and everything seems hunky dory(sp?)
So I thought - Driver update. Searched the web, no drivers out there
and the
zydas website does not exist anymore. www.zydas.com
I will start another thread to see if anyone has a driver.
(I still think it might be a permissions thing too)
Thank you for all of your help. Any more words of wisdom are very
welcome.
-halli-
There are 638 identified and unidentified users. To see the list of identified users, Click here.
