Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I have been out of the graphics card game for quite some time. I have
a GeForce4 4200Ti, AGP 128MB graphics card. I play CS Sourse and HL2
a lot and i am sure my card is slowing my system down. What would be
worthwhile upgrade of my card for the min amount of money, i only have
about £50 to spend. Also, is PCI express better than AGP 8x???
"edrafp" <UseLinkToEmail@HardwareForumz.com> wrote in message
news:7_293532_628d4e4e0768e91b2e5a0015b3524737@hardwareforumz.com...
> Thanks
> Ed
> AMD XP2800+ (11x200=2200mhz 400mhsFSB)
> 512 MB DDR 400 Samsung PC3200 (Dual Channel)
> ASRock K7V88
> GeForce4 4200 Ti
> Seagate 80GB Barracudda
-- For 50 pounds(don't have the pound sign) or what, $75 U.S. ,your not
going to get much if any improvement. You'll have to do a little better like
an nvidia 5900 or ATI 9800 pro. Even then some newer games like Battlefield
2 will bog down.The Nvidia 6600GT is the swett spot right now but it costs
$160(here in the U.S.) for an OEM card.
PCI-Express requires a new motherboard on your part, you know. You can only
use an AGP model with your board. And at only 50 Pounds you are not going
to get a video card that faster than your current one.
DaveW
> Thanks
> Ed
> ASRock K7V88
> GeForce4 4200 Ti
> Posted using the http://www.hardwareforumz.com interface, at author's
> request
> Articles individually checked for conformance to usenet standards
> Topic URL:
> http://www.hardwareforumz.com/Nvid [...] 58090.html > Visit Topic URL to contact author (reg. req'd). Report abuse:
> http://www.hardwareforumz.com/eform.php?p=293532
I would second the recommendation for an AGP 6600GT.
Stoneskin
> U.S. ,your not
> little better like
> like Battlefield
> now but it costs
> Stoneskin
> [Insert sig text here]
Would a Fx5900 be an upgrade for me from the 4200Ti ??? Would it make
that much difference????
Fully DX9 compliant? HL2 does not think so.
DaveL
"Stoneskin" <no@thanks.com> wrote in message
news:MPG.1d2db8853804fded989b97@nntp.dsl.pipex.com...
> You should see a difference - the FX5900 is a faster card and also fully
> DX9 compliant.
> Check out http://graphics.tomshardware.com/g [...] index.html > for a direct comparison between the Ti4200 and FX5900 among several
> other cards.
> Stoneskin
Yes.
news:7_294046_e82c47738057d0a301a0dd29a89df560@hardwareforumz.com...
> > U.S. ,your not
> > little better like
> > like Battlefield
> > now but it costs
> > Stoneskin
request
> Topic URL:
http://www.hardwareforumz.com/eform.php?p=294046
