G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I am trying to install 2 x PNY Nvidia 6600 GT SLi video cards into my Asus
A8N-SLi Deluxe motherboard, however I can't get the nvidia software to give
me any SLi options under windows as decribed in the manual for the
motherboard. My OS is Windows XP SP2 fully up to date through windows
update.
All the hardware is where it should be, the SLi bridge, power to the EZ plug
etc.
I have down loaded the lastest Nvidia Video card drivers (version 77.72) and
the latest drivers for the nForce4 chipset (6.53).
Similar to another user on here my original motherboard BIOS version was
1006. When I went into the BIOS to check any possible settings it didn't
have the "SLI Mode" option in the Advanced menu, however it had an "SLI
Configuration" sub-menu inbetween "Onboard Device Configuration" and
"JumperFree Configuration". The only option that was available under the
"SLI Configuration" sub-menu was "EZ-Plug Warning" (enabled or disabled).
I updated my BIOS to 1011 and it still doesn't have the "SLI Mode" option
though now there is 2 more options under "SLI Configuration" along with the
- SLI Broadcast Aperture (auto or disabled)
- AI-Selector (auto, single video card or dual video card)
I have tried all these options apart form 'single video card', I have
changed the position of the video card selector to dual (the thing in
between the 2 PCIe slots) get no SLi options in windows.
The Windows does recognise 2 6600 GT video cards
According to tech sites I have browsed over the weekend I should get 'greyed
out' SLi optins in when there is only 1 card present I don't get this
either..
As I have updated the drivers ond the MB bios I am now struggling to see
what to try next....
update.
etc.
either..
