help setting up dual monitors please
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I know I had this working before, but then I moved and was
using only one monitor for a while so messed with the settings.
Now I can't figure out how I set it up previously.
I'm running a 6800 with dual monitors. I used to have it
so each one had its own resolution and refresh rate. Going
into the nvidia display properties, if I set it for dual monitors
configured horizontally, it treats both monitors as one,
with one very wide resoluion and one refresh rate. Plus the
windows task bar spans both monitors where it used to
only appear on the primary one. I don't see any other setting
that seems to be appropriate (single, clone, dual horizontal,
dual vertical). How do I set these independently? I also
have Powerstrip installed but I'm having no luck with that
either. Thanks!
More about : setting dual monitors
Anonymous
Monitor Authority
"RobR" <nospam@nospam.com> wrote in message
news:63_Ne.903$N22.298@trndny07...
> either. Thanks!
On my workstation with a QuadroFX 3400 w/ 2 LCDs, I use the dual-view
setting, and can control independently either of the screens. I also had to
use the monitor position from display properties Settings tab to adjust the
position of the second monitor (different monitor base = different Y
position). But some applications have problems running in dual view, so I
have a hotkey shortcut to change my 'profile' from dual to single when
needed.
Luc Monod
Patt-Technologies, Inc.
St-Eustache, QC
Canada
"Luc Monod" <LMonod 'at' Patt-Technologies 'dot' com> wrote in message
news:4309df64$1@usenet.ugs.com...
>> either. Thanks!
> to use the monitor position from display properties Settings tab to adjust
> the position of the second monitor (different monitor base = different Y
> needed.
> Luc Monod
> St-Eustache, QC
> Canada
I just dont see a 'dual view' setting other than the ones I mentioned. I'd
almost think
I'd need to update the driver except for the fact this used to work with the
driver
I currently have installed :) . This should be a piece of cake, I'm not sure
why
I'm having so much difficulty.
Anonymous
Monitor Authority
In article <RylOe.5873$Fq2.1262@trndny03>, nospam@nospam.com says...
> >> either. Thanks!
> > needed.
> > Luc Monod
> > St-Eustache, QC
> > Canada
> almost think
> driver
> why
Having just gone through the same of you I found that you have to use
the display wizard, either TV or Display from nView Desktop Manager /
nView Properties.
In the process of fiddling around with this though, I've managed to open
an application in one window state that now open off screen when not
maximised, so if anyone knows how to reset the screen postion of an app
I'm listening!
Wooky
Related ressources
Anonymous
Monitor Authority
> nView Properties.
> I'm listening!
> Wooky
'Display Properties' \ 'Settings' tab \ 'Advanced' \ 'nVIDIA' tab \ 'Desktop
Management' \ 'Windows'
check 'prevent windows from opening off-screen'
Luc
Anonymous
Monitor Authority
In article <430b1f6d$1@usenet.ugs.com>, "Luc Monod" <LMonod 'at' Patt-
Technologies 'dot' com> says...
> > nView Properties.
> > I'm listening!
> > Wooky
> Luc
Thanks for the tip but unfortunately that didn't do it, it was
determined to open where it wanted.
I knew of the alt/space M command to move windows, as the mouse cursor
changes to a move icon I tried to move it back with that, it didn't
work. What I hadn't realised was that you could move the windows with
the cursor keys, that did fix it :-)
Cheers
Wooky
Anonymous
Monitor Authority
Use the Taskbar and choose Move. Then insure you use the keyboard to move it
back into the display. DO NOT USE your mouse to do it.
"Wooky" <nib@nob.net> wrote in message
news:MPG.1d75572b21322e06989697@nntp.dsl.pipex.com...
> > > nView Properties.
open
app
> > > I'm listening!
> > > Wooky
'Desktop
> > Luc
> Cheers
> Wooky
Anonymous
Monitor Authority
"pjp" <pjpoirier_is_located_at_@_hotmail_._com> wrote in message
news:MNTOe.79169$Ph4.2491837@ursa-nb00s0.nbnet.nb.ca...
> it
I remember loosing the variable table for Solid-Edge on my screen somewhere,
it's not located as an application on the taskbar. Took me 2 days to find
it. Lost beneath my Taskbar ...
Good reason to have multiple screens, you don't have to move windows around
to work.
Luc Monod
St-Eustache, QC
Canada
news:RylOe.5873$Fq2.1262@trndny03...
>>> either. Thanks!
>> adjust the position of the second monitor (different monitor base =
>> different Y position). But some applications have problems running in
>> dual view, so I have a hotkey shortcut to change my 'profile' from dual
>> to single when needed.
>> Luc Monod
>> St-Eustache, QC
>> Canada
> I'd almost think
> the driver
> sure why
OK I figured out the problem I think, just not sure how to solve it.
XP itself only thinks I have one monitor. I can't get it to install or
detect the second one. The nVidia driver correctly lists both
monitors but I don't have the dual view options and I assume that's
because XP itself needs to know about it.
news:MPG.1d74fce4cefd4f6989696@nntp.dsl.pipex.com...
> nView Properties.
> I'm listening!
> Wooky
All I can say is.... WTF?!?!? I've had my second monitor off now for a few
days and haven't gone back to looking at this problem. After reading your
post, I went to go try what you suggested, turned on my other monitor and
it was working exactly the way I wanted!!! I hate psychic PCs.
Ask the community
