Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a linksys wireless router connected to a cable modem. When I connect a PC equipped with Windows XP home addition using an ethernet cable, I can reach the internet.
When I disconnect my ethernet cable and install a PCMCIA (Proxim) wireless card or an external USB (D-Link DWL-122) wireless USB adapter I cannot reach the internet. I have WEP turned off, I do obtain a valid IP address using DHCP and do not have any MAC filtering turned on.
On Sat, 24 Apr 2004 20:31:06 -0700, johnbu <anonymous@discussions.microsoft.com>
>Any help is appreciated.
John,
Do the D-Link or Proxim drivers provide any diagnostic?
Please provide ipconfig information for the computer, with the ethernet cable
and then with a wireless device enabled.
Start - Run - "cmd". Type "ipconfig /all >c:\ipconfig.txt" into the command
window - Open c:\ipconfig.txt in Notepad, copy and paste into your next post.
Please provide static route tables for the computer, with the ethernet cable and
Start - Run - "cmd". Type "route print >c:\route.txt" into the command window -
Open c:\route.txt in Notepad, copy and paste into your next post.
With the wireless device enabled:
1) Ping www.yahoo.com. 2) Ping 66.94.230.33.
Report error messages.
Cheers,
Chuck
Paranoia comes from experience - and is not necessarily a bad thing.
