Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi,
Sorry for the swearies in the title. I really have felt like throwing
my PC out of a window on several occasions this week!
This problem relactes to the windows 98se partition on my hard disk
(some software can be very fussy about it's running conditions...)
Yesterday, I had a directx-less installation, with the latest nvidia
drivers (77.72), all was fine, and I was running in 1280*1024
resolution. I have a geforce 6600 card, from PNY.
Yesterday I decided to install directx cersion 8.0 (one piece of
software never did want to run on 8.1...). So I did the usual switch to
PCI graphics, clean the nvidia drivers (used driver cleaner), ran
direct x radicator even though I didn't have dx on there...
The issue I had here was that shurdown didn't seem to work properly -
the display output turned off, so the monitor went into power saving
mode (as if the pc was actually off), but it went on to "play" the
windows startup again, I waited until the hard disk was not in action,
and rebooted using ctrl-alt-del...
After installing directx 8, and the nvidia drivers, I am unable to
select any resolution above 640*480 in 256 colors... 32 bit isn't
available on the control panel, and whataver else I select it always
reverts to 640*480... control panel reports the display adaptor as
"geforce 6600" and the drivers seem to be correctly installed
I tried reinstalling the monitor driver from the cd. no luck
I tried removing NVVIDIA drivers and direct x and reinstalling DX and
the nvidia drivers - no luck
Tonight I will see if it lets me go back to driectx-less, and see if I
can rule out the version of direct x - but are there any other ideas?
Hi,
