G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hi, I'm hoping someone has the answer out there....
I've just bought the above card and put this into my kids PC to replace the
onboard graphics for simple games like HP. Here's what I've done so far -
deleted the ProSavage 3 DDR onboard graphics driver, changed the BIOS
setting to use the new AGP so there's no memory allocated. Installed the new
card & drivers. System boots up but when Windows ME gets to the second
window ready to the my monitor (an oldish CRT but with good picture)
switches into standby? As far as I can tell the system is loading up etc, as
it closes down and reboots OK. I can't get into windows safe mode either. A
bit long winded but and it should be compatible with my Asrock K7VM2 Athlon
motherboard - help please...
Thanks
Adrian
Thanks
Adrian
