Archived from groups: alt.comp.periphs.videocards.nvidia (
More info?)
I placed a Zalman heatsink on my FX5200 and it's been working silently for
18 months. The only drawback was that it does block the first PCI slot next
to the AGP slot.
http://www.zalman.co.kr/eng/product/view.asp?idx=114&code=013
"Robert Gault" <robert.gault@worldnet.att.net> wrote in message
news:R0rVe.236587$5N3.107315@bgtnsc05-news.ops.worldnet.att.net...
> mistersmitty@hotmail.com wrote:
>> I have GxForce 5200 and the fan is making lots of noise.Card works
>> great but the fan is the problem.
>> Is it possible to replace the fan within this card?If so what would
>> people recommend.Or should I just get another video card?
>> TIA
> If the fan is noisier than when first installed, then you can try oiling
> the bearings. However, if the fan has always made the same amount of
> noise, that's what you can expect from fans with small blades and high
> speed.
> If you slow down the fan with a speed controller, you risk overheating. If
> you replace the fan assembly with an after market unit, it will probably
> be just as loud. If you want to experiment, you could try what I did with
> a Ti-4200 card. I removed the fan assembly and strapped a box fan to the
> card. The fan is powered from a motherboard connector. The result is a
> completely silent video card with greater air flow over the heatsink.
