New ati radeon 9800pro issue...
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi i did buy the ati radeon 9800pro and i'm having trouble when
benchmarking or playinng game it luck up and freez my system.
10 answers Last reply
More about radeon 9800pro issue
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    You must be one lucky guy.
    -Bill (remove "botizer" to reply via email)
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Hi, i did buy the ati radeon 9800pro and i'm having trouble when
    benchmarking or playinng game, it luck up and freezevery time i would
    love to know what to do with this.
    Can it be a problem of power supply or those it come from a defective
    videocard?
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Maybe not. Try an overclocking tool like ATI Tool.exe and try underclocking
    the memory and core, then see if it still locks up when playing a game. If
    not, your card is just running a little hot.
    Gary
    Tweaks & Reviews
    www.slottweak.com
    "DreamMaker" <onesuponatime@yahoo.ca> wrote in message
    news:shu570l2a7mqjoor3dk1vgk22ok92mm25u@4ax.com...
    > videocard?
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    DreamMaker <onesuponatime@yahoo.ca> wrote in message news:<shu570l2a7mqjoor3dk1vgk22ok92mm25u@4ax.com>...
    > videocard?
    Might be overheating, my card is in RMA because... it overheated. And
    now the shop can take a look at it... probably it will be send back
    with "it works.. but it runs slightly hot" ... oh well.. I guess I
    have to put allot of cuperwork on it!
  5. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    On Tue, 6 Apr 2004 14:58:08 -0400, "GTX_SlotCar" <deroy@maine.rr.com>
    >Gary
    hmm by doing so, i'm reducing the (amp/wattage on the VC so it less
    stress on the psu) ?
    i will check it out, thanks....
  6. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Obviously you need to ascertain that it is indeed the new video card that's
    causing the lockup and instability problems.
    It could be a number of things that's causing the problem. from poor power
    supply to a corrupted driver etc.
    My first Powercolor 9800 Pro would not even let my system boot, but it would
    work in my wifes machine. Despite trying another power supply and other
    desperate measures such as booting with only the video card plugged in. In my
    case it was a faulty video card.. a replacement resolved the issue and all has
    been well since.
    Its a case of elimination, try another power supply if one is available, put
    your bios settings back to defaults, slack off any memory timings etc.
    Try turning off fastwrites, and running in AGP-4 mode if its currently 8.
    Is it only giving trouble when running 3d apps? if so it may be driver issue or
    Directx has got corrupted, could also be heat related of course.
    Unfortunately there is no definitive sure answer... The first thing I always do
    if I start getting un-explained lockups etc. is to run 'Mem86' which gives the
    memory a good testing, most problems I've had in the past have been down to a
    faulty memory module.
    But if it was working okay before you changed the video card then obviously the
    card itself has got to come under suspicion.
    Hope you sort it.
    Regards
    John
  7. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    On Tue, 06 Apr 2004 19:17:59 GMT, John <dy73ui39aHe5@cableinet.co.uk>
    >been well since.
    >Hope you sort it.
    >Regards
    >John
    Thank you for the support. i first start to disconnect a drive and a
    cd burner and get the latest driver "catalitsys"
    Now i'm able to run some 3d applications to the end of the test like
    3dmark01 and 03. That is good, It work. alltough that i got a small
    300watts psu that is in fact supposedly capable of running the
    Videocard, by chance it does.
    i guess when installing new component in the machine it give a little
    strange smell like over heating ( maybe thats because its the most
    powerfulll VC on the market, not to mention the xt vr) ... but what
    can i say it doent crash anymore so i guess it was a factory driver
    issue.
    I'm gone a plug back the drive just to see if it lock up.
    cia
  8. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Well, many of the issues with this card is that the memory runs hot. By
    underclocking the card, it'll produce less heat. If it runs this way, but
    not at stock clock rates, it means the memory is getting hot and some
    ramsinks would cure the problem.
    Gary
    Tweaks & Reviews
    www.slottweak.com
    news:ke9670515r8dal5v7dok8khp0qh9jsut21@4ax.com...
    underclocking
    If
    > >Gary
  9. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    news:br86709hlufncjqak9l1j5k9fq171v6uue@4ax.com...
    > issue.
    What gives of the smell? The PS or the ATI card? Dude nothing should smell
    when you install it for the love of God! I think you have much bigger
    problems then your new 9800Pro. JLC
  10. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    >been well since.
    >Hope you sort it.
    >Regards
    >John
    Hi i did some test with memtest86 vr3 and it didnt show any error in
    ecc and non ecc. i did the test 2 time and it show no error.
    the test:
    So on that side i'm ok.
    it would be nice if it was able to test the video memory too.
    Some conclusion:
    But i would say that driver are a big issue here and the way the
    videocard is manufactured. no heat spreader on the memory chip that
    become very hot under heavy load. l did touch the card once one mins
    after the computer was off and disconnected and wooo hooo it hot near
    the agp slot ( mem chip) and less on the auther side...??? Lets say
    that the fan is less bigger than the one i got on my old fx5200td asus
    Maybe i should'nt complain, because i did pay the card 266$ us.
    The situation:
    now i'm at the point where i will reduce the memory speed of the video
    card. Pffff overheating, so ati sells 9800 or maybe 9700 video card oc
    to a 9800pro by that there is no way i will be able to do OC with that
    kind of heating problem. Lets say that on the memory chip of the card,
    there is no heat spreader... i will say... Is this normal? i should'nt
    have to buy these heatspreader and stick it on the memory and by that
    risking my investment...
    The brand name:
    The videocard is suppose to be made by ati it self so it's not an
    albatron or a powercolor or an asus...
    Finally:
    I'm gone end with a 9700 maybe less, but to do that i will need the
    specific program to reduce the frequency of the card. Could you help
    me on that one????
    if the performance are gettig to low with the new setting i'm gone
    return that thing...
Radeon Games ATI Graphics
