Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I am currently operating a 3-PC LAN which is tied together with an
SMC7004ABR 4-port router. The router is connected to the outside world with
a cable modem. Two of the PCs are running Windows XP Pro, and the third one
uses W98SE.
I would like to add wireless to this LAN so that I can access the internet
(or access the other PCs) from a laptop located anywhere in my house, or
even outside in the back yard
Can I simply plug a wireless router into the unused port on the SMC wired
router, and then operate the laptop equipped with a wireless card - or is
there a simpler or less expensive way to go?
>uses W98SE.
>Thanks.
Papa,
Hanging a second router off the first would be a simple way to add a wireless
segment to your wired LAN.
If you buy a wireless router, the router function in it will make a second LAN
segment. Configuring your laptop, and your wired computers, to communicate on
two separate LAN segments, will be rather complicated. So you'll probably end
up connecting the wireless router as a wireless access point.
Thanks to mass merchandising, though, a wireless router will cost less than a
comparable wireless access point. For comparison purposes only:
Whatever you end up buying, please use security precautions. With a wireless
network, your network may extend far outside your front door. You could have a
neighbor several block away, sitting comfortably in a Starbucks, and accessing
your LAN.
Here's a story about somebody's very stupid wireless neighbor. Don't expect all
wireless neighbors to be this stupid.
<http://www.canoe.ca/NewsStand/LondonFreePress/News/2003/11/22/264890.html>.
The point is, you need to protect a wireless LAN with more precautions than just
the NAT firewall.
Enable WEP / WPA. Use non-trivial (non-guessable) values for each. (No "My dog
has fleas" ).
Enable MAC filtering.
Disable DHCP, and assign an address to each computer manually.
Change the subnet of your LAN - don't use the default.
Change the router management password, and disable remote (WAN) management.
Don't disable SSID broadcast - some configurations require the SSID broadcast.
But change the SSID itself - to something that doesn't identify you, or the
equipment.
Enable the router activity log. Examine it regularly. Know what each
connection listed represents - you? a neighbor?.
Install a software firewall on every computer connected to a wireless LAN. Put
manually assigned ip addresses in the Local (highly trusted) Zone. Open the
following ports for file sharing only in the Local Zone: TCP 139, 445; UDP 137,
138, 445.
Use non-trivial accounts and passwords on every computer connected to a wireless
LAN. Disable or delete Guest userid. Rename Administrator, to a non-trivial
value, and give it a non-trivial password. Never use the Administrator renamed
account for day to day activities, only when intentionally doing administrative
tasks.
Stay educated - know what the threats are. Newsgroups alt.internet.wireless and
microsoft.public.windows.networking,wireless are good places to start.
Cheers,
Chuck
Paranoia comes from experience - and is not necessarily a bad thing.
Thanks, Chuck, for a VERY complete and useful response - which I am going to
print out for future reference.
One of the routers you mentioned, the SMC7004AWBR Barricade Cable/DSL
router, sounds interesting. From your description, it looks like I could
just simply discard my wired SMC7004ABR router and use the SMC7004AWBR
instead. With it, I assume I could just plug the CAT 5 cables from each of
my 3 desktop computers into this AWBR router and still have the same wired
LAN configuration I have now. Then, as I understand it, this same AWBR
router could also be used to communicate with my laptop equipped with a
wireless card - thus resulting in the 3 wired desktop PCs plus the wireless
laptop all being on the same LAN. Please correct me if I am wrong. I realize
that some settings will probably need changing.
>Thanks again,
>Papa
Glad to help, Papa.
You have the right idea - if you're going to have a LAN with mixed wired and
wireless computers, and allow file sharing between everything, using a single
router is much easier to setup properly.
And, by buying another router from the same vendor as what you have right now,
you'll already be familiar with some of the setup. Now concentrate on the
wireless configuration, which is a lot of fun in itself. %-]
And, with its being easier to setup, you will be better able to use the proper
security procedures. Which is better for everybody - except for the wanna be
wardrivers in your neighborhood. ;-}
Cheers,
Chuck
"Chuck" <none@example.net> wrote in message
news:l75690tnh8ep7n261iflv6jp9svef4k7fq@4ax.com...
to
of
wired
wireless
realize
> >Thanks again,
> >Papa
> Glad to help, Papa.
and
single
now,
proper
be
> Cheers,
> Chuck
Yeah, I got a big chuckle out of the "wardriver" story you quoted.
After taking a look at the specs for the SMC7004AWBR, which has 3 Ethernet
ports, I discovered the almost identical (but with 4 Ethernet ports)
SMC7004VWBR. It is a little newer in design too, so I may go with it. The
extra port will come in handy for the occasional PC I might be building
(something I do as a hobby and to furnish friends with PCs).
