Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I have a P4 2.5, and 512 megs of ram. I'm in need of a new video
card. I have no experience with ATI cards, but want to give them a
try. My other problem is my power supply is only 250 watts. Should I
just wait until I can replace the power supply and get a better video
card, or is there an ATI model that will still work ok? Mostly into
FPS, (not that many though) Flight Sims, and Racing. (NR2003 mostly)
Thanks,
Andy
I have the same setup except 1GB RAM and went with the ATI9600XT. No power
connection required and installation was a snap. I use Flight Sim 2004 for
gaming exclusively and am pleased with the card. Only thing is when looking
left and right from the 2D cockpit the repaint/draw is somewhat slow.
Bill
"Andy" <andy@nospam.com> wrote in message
news:sk159013m9sfn0nkfr9b6dfqdb56frs675@4ax.com...
> Thanks,
> Andy
Bill, the power comes from the PSU.
I think you missed it.
He should definately upgrade his PSU first.
"Bill" <not@home.com> wrote in message
news:zDykc.61128$Uz1.29894@bignews3.bellsouth.net...
power
looking
> Bill
> > Thanks,
> > Andy
Yes I understand and knew that. My point is with a 250W PSU you can use the
9600XT with no problem and no need to upgrade the PSU. The 9600XT does not
require a power connection or PSU better than 250W. Other high end cards
recommend 350WPSU and do require a power connection to the PSU
If he isnt ready or willing to upgrade the PSU then the 9600XT is a good
choice.
Hope I explained it better.
Bill
"Buffalo" <eric(nospam)@nada.com.invalid> wrote in message
news:ToAkc.758$TD4.69885@attbi_s01...
> power
for
> looking
> > Bill
> > > Thanks,
> > > Andy
>choice.
>Bill
Thanks Bill. That was the way I understood it. (that the 9600XT
doesn't require power from the power supply.) I still might just wait
and upgrade the PSU anyway, then opt for one of the higher end ATI
cards. I just don't want to "waste" my money on a video card that is
also going to be limited by my CPU. (P4 2.5)
Thanks again,
Andy
news:nbe790tlrug2u6q2jeg6bpl5b721sfhitc@4ax.com...
the
not
> >choice.
> >Bill
> Thanks again,
> Andy
Thats a good approach Andy. I see too many people getting high end cards for
under powered CPU's as well as PSU's and then complain.
the
not
> >choice.
> >Bill
> Thanks again,
> Andy
All components in the PC draw their power from the PSU, except for the PSU
itself.
Does the 9600XT draw power from wall socket?
news:ETPkc.8522$I%1.732787@attbi_s51...
> the
> not
cards
good
> > >choice.
> > >Bill
> > Thanks again,
> > Andy
> itself.
No it draws it from the PSU but you DONT need to run a separate power
connector like the other high end cards...thats a little wire with
connectors on both ends..one runs from the card and the other to the PSU . I
can draw a diagram if it would help. And like I said it doesnt need more
than a 250W PSU.
news:EhRkc.51735$oN1.26428@bignews5.bellsouth.net...
use
> > the
does
> > not
> cards
> good
> > > >choice.
> > > >Bill
> > > Thanks again,
> > > Andy
PSU
> > itself.
I
> than a 250W PSU.
That all depends on how much the other devices draw and what voltage bus the
vid card draws from.
I know about the separate connectorused to take the load off the MB and
supply more power than the MB transformers or circuity can, if needed).
Some MB's draw a lot off their 5v bus and convert it to other voltages.
That 250w PSU is probably too small, then again, you may be correct.
He should probably get a PSU with at least 30amp on the +5.0v bus and 15amps
minimum on the +12.0v bus.
