Tom's Hardware > Forum > Graphic & Displays > ATI > Sapphire 9800 Pro installation problem
Forum Graphic & Displays : ATI - Sapphire 9800 Pro installation problem
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi,
I had a 7500/Athlon 2100+/Abit KR7A-133. I bought a Saphire 9800 Pro.
When i install it, (just replacing the 7500 by the 9800 and plug the card power
cable), i get no signal on the monitor. Nothing.
When i install back the 7500, everything run fine.
Do you know what i miss ? A setup in the motheboard bios ?
Thanks a lot for any advice.
Regards
Christian
Sponsored Links
Sounds to me like you might have a DOA.... Unless you're not connecting the
monitor properly, or making sure the key is seated all the way down and the
back of the card is locked?
"XtianBresson" <xtianbresson@aol.com> wrote in message
news:20040501031323.07231.00000674@mb-m02.aol.com...
> Hi,
power
> Regards
> Christian
Reply to Xeon
I had the same problem, but with the saphire 9600 xt. I called Saphire and
after some troubleshooting they told me the card was defective. Then I
called the vendor (Allstarshop.com) and told them what was what. I sent the
card back to them and I should get a fully tested replacement by thursday.
Call Saphire tech support.
Hope this helps.
> Hi,
power
> Regards
> Christian
Reply to bill
There are 517 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
