G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Is there any of the Radeon 9800 Series that run at other than 1.5 volts?
I am considering the purchase of a MOBO that specifies it will only
"support" AGP cards running at 1.5 volts. Does this setting require some
fiddling on my part, or is this the default "running" setting for the cards.
The MOBO is the SOYO SY-P4I875P-D2 card, FWIW. For the video I was thinking
about the 9800 Pro.
Thanks for your help.
Pablo Rivera
Apprentice Developer
Vision for Productivity
about the 9800 Pro.
Pablo Rivera
