Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
I have done exactly this. I had a splitter for the line going to 2 TV's.
When I got cable internet, they split the line again, and ran a line to the
computer. I then split that line to both the cable modem and my ATI all In
wonder tuner. No signal loss or picture quality problems. Apparently, I
must have a very good signal.
"David" <gorenstein@msn.com> wrote in message
news:NLppc.53573$z06.7575318@attbi_s01...
> Thanks-sounds like I should be able to go the splitter route which is an
> easy solution.
> dg
> "Glzmo" <glzmo@NOyahooSPAM.com> wrote in message
> news:stppc.98976$O9.91183@news.chello.at...
> > news:4eppc.52573$536.9026576@attbi_s03...
> > > This is probably a stupid question-I have a high speed cable
connection
> > > going to my computer. If I buy a TV capture card, do I just use a
> > splitter
> > > on the incoming high speed data line to receive my TV signal or will I
> > have
> > > to use another cable line for a TV signal?
> > It depends how the cable company handles the internet signal. While most
> > have the internet signal on the same line as the TV channels, some have
> > seperate lines for each. AFAIK, some companies can also enable/disable
> > channels on lines and such.
> > If both the TV signal and the signal responsible for data transfer are
> > enabled on same line, you could probably use a simple splitter to get
> both.
> > However, this will decrease signal quality a bit, which isn't that big a
> > deal unless the signal is weak to begin with.
> > I hope this helps,
> > Glzmo
