XP SP2 Firewall Problem
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
I recently slipstreamed SP2 into my Windows XP installation CD. I followed
the procedure listed at http://www.msfn.org/comments.php?shownews=9235 to
create my bootable CD from my original XP CD. The slipstream processes with
absolutely no errors and completes.
When I use this new CD to do a new install everything appears to work
correctly and the system installs and works fine, but when I try to access
the Windows Firewall settings in Security Center I get the following error
message:
"Due to an unidentified problem, Windows cannot display Windows Firewall
Settings"
Now if I reinstall SP2 on top of the current install I am able to access the
Firewall settings, but I would like to find out why this is happening on a
fresh install of Windows XP w/ SP2 integrated into the install CD.
Any help will be greatly appretiated.
Chris Buckbee
3 answers Last reply
More about firewall problem
  1. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    > message:
    > Settings"
    Hi
    Instead of reinstalling SP2, see if registering the following DLLs helps
    (but I have no clue about what causes this problem in the first case).
    From Start/Run, run the following commands:
    regsvr32 %windir%\system32\atl.dll
    then
    regsvr32 %windir%\system32\hnetcfg.dll
    regsvr32 %windir%\system32\netshell.dll
    regsvr32 %windir%\system32\netcfgx.dll
    regsvr32 %windir%\system32\netman.dll
    Then do a reboot.
    torgeir, Microsoft MVP Scripting and WMI, Porsgrunn Norway
    Administration scripting examples and an ONLINE version of
    the 1328 page Scripting Guide:
    http://www.microsoft.com/technet/scriptcenter/default.mspx
  2. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Registering the DLLs and the restarting did not fix the problem. I am still
    not able to access the Firewall settings. I checked the Services on the PC
    and it shows that the Windows Firewall service is started, but when I try to
    access the settings I still get the same error.
    Chris Buckbee
    > > message:
    > > Settings"
    > Hi
    > then
    > Then do a reboot.
  3. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Hi
    Please try this:
    Start/Run --> cmd.exe
    and then, in the command prompt, type:
    netsh.exe winsock reset
    and hit Enter
    If that doesn't cut it, try this one
    http://www.spychecker.com/program/winsockxpfix.html
Firewalls CD-Rom Windows XP
