G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi guys, my pc crashed last week and I had to reformat. I'm trying to
install my PCI TV wonder and am having a couple of problems.
The Windows Media Encoder does not complete it's install, it hangs at the
very end. Then if Windows looks for the drivers to install the TV wonder it
says it can't find 'atibtcap.sys' I can't find the file anywhere on my
system, even as a hidden file. I have XP home. Done all upgrades, DirectX
9.0b. The files are downloaded from the ATI support site except I'm using
version 7.9 of the Media Center, not the newer version on the website (9.0).
Before the crash it was working just fine, with the same pc. Is it possible
that a windows update could have caused this. Any help would be great.
Thanks.
Thanks.
