Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wireless Connection unavailable
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi
I am trying to establish a peer to peer network between my laptop(XP Home, PC Card 802.11g) and desktop (XP Pro, USB Wireless dongle 802.11g). When they are both inserted I still get the message wireless connection unavailable, it is as if they aren't plugged in. I have set up the details as per the windows wireless networking tabs, for peer to peer. I can find answers for joining an excisting network but do i have to establish the network on one of the machines first ?
I am not computer illiterate, but this has beaten me well and truly !
Sponsored Links
I can only advise what I did, I firstly established the link between the two
computers using a crossover cable. I then obtained a Belkin components
which as soon as I installed the link they worked. It is important to
establish then setup on your main computer before you attempt to set up the
laptop. If using USB and you have more than one socket always use the same
one. I would as you are using XP roll back then start with your main
computer, install the software check that it is working via Device manager,
then go onto the laptop and repeat.
Good luck
Ray
This E-Mail has been checked by eTrust EZ Antivirus
"David J Smith" <anonymous@discussions.microsoft.com> wrote in message
news:A010B7AB-0719-45D5-B211-BAB386BE1314@microsoft.com...
> Hi
Reply to ray
One of the first things you need to do is make sure your
firewalls will allow you to connect to each computer.
each computer may be seing each other as a threat rather
than a peer
>-----Original Message-----
>Hi
well and truly !
Reply to john
There are 840 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
