G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I'm still having problems with gamma in 3d games. If I play an older game
without it's own gamma control (i.e relies on the ati drivers for it's gamma
settings), then I play a newer game with a gamma control, then go back and
play my older game again, it's very dark, no gamma is applied.
If I reboot between games, or reset the gamma in the control panel, it works
ok.
Ati have exhausted lots of options with me, to the point they are saying the
card may be faulty, however it works perfectly in every other way.
If anyone has any suggestions as to what I may try, or if they have this
same issue etc. I'd really appreciate it, my card is a sapphire radeon 9800
pro 128mb.
thanks in advance
ok.
pro 128mb.
thanks in advance
