Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
On Fri, 4 Jun 2004 08:59:34 -0400, "Lightnen"
<lightnenNotHere@mnsi.net> wrote:
>Thanks there Patrickp for the Advice and the helps: Went to the ATI sight
>you included in post and found a removeal tool that sees to have worked
>GREAT guess I hadden't removed everything like I thought I had.. LOL..
>anyways Hopefully this works better.. if the newer vid cards are better than
>this 9600xt well don't know what to say for this seems like a great card for
>sure..
> Anyways Thanks again..
> Lightnen
You're welcome, Lightnen. You should know that Ati and NVidia (and
they're not the only manufacturers presenting this problem now) both
have very inadequate driver removal processes: if you look on the
Rage3D forum, for instance, there are threads devoted to cleaning
driver remnants from your system.
But, as you found, the cat-uninstaller utility (I presume that's what
you're referring to?) does a pretty good job for Ati drivers and
software. Generally speaking many people report upgrading their
drivers without uninstalling the previous ones without problems (I
always clean my system before a driver upgrade anyway and would
recommend doing so), but downgrading can be problematic, and changing
brands can be a major headache.
That's right; the 9600 cards are excellent - I have a Sapphire 9600
Pro VIVO myself. The 9700s and 9800s must be really something, and as
for the the new cards coming out now...
>"patrickp" <me@privacy.net> wrote in message
>news:840vb056ivkb97onrqbhhejhup2p8pmrr3@4ax.com...
>> On Thu, 3 Jun 2004 09:26:58 -0400, "Lightnen"
>> >Hi there People:
>> > Well thought this was a good vido card but after a day not even I'm
>> >getting BLACK screen, seems like the monitor looseing connection. It
>comes
>> >back but then its very distorted and wrong size have it done 4 times this
>> >morning in about 2hrs.. Have checked all setting and everything seems
>fine..
>> >The system should be able to handel this card, prcess AMD 900. power
>supply
>> >350amp dual fan. monitor set at 1024x768. windows XP pro have not been
>able
>> >to find a sight for any updates to drivers. But system say its working
>> >fine.. hmmmmm any help would be Greatly Appriciated..
>> Go to
http://www.ati.com/support/driver.html for Ati card drivers,
>> Lightnen, or if you have an OEM card look on your OEM's site as well.
>> But DO NOT allow XP to look for drivers for you. We see many problems
>> posted here by people who've done that. In general, when using
>> Windows update processes, you should install critical updates,
>> although not without considering them first, only install Windows
>> updates if you think you need them and they're appropriate, and NEVER
>> update your drivers that way - except possibly for M$ products.
>> patrickp
>> patrickp@5acoustibop.co.uk - take five to email me
patrickp
