Archived from groups: alt.sys.pc-clone.packardbell (More info?)
The power supply in my Multimedia 7900 recently died and I also have
an old Legand 4610 lying around that has seen better days, but the
power supply apparently still works. Frankly, I've been hearing a lot
of horror stories about Packard Bell proprietary parts and I was just
wondering if I could use that older power supply in the 7900. Are
they compatible? I appreciate any info that anyone could give me.
Give me the serial number from each unit
and I can tell you
There may be someone here who knows the model specifics
"Igor" <thoovler@excite.com> wrote in message
news434b6c6.0408092232.16823e63@posting.google.com...
> Thanks
For the most part, PB did not use power supplies with proprietary connectors.
Some PB power supplies have strange shapes. Nearly all PB power supplies have
an uncomfortably low wattage rating which makes upgrades sometimes
problematic... Ben Myers
>Thanks
ben_myers_spam_me_not @ charter.net (Ben Myers) wrote in message news:<411907bc.5239835@news.charter.net>...
> >Thanks
Well, I finally managed to get into the machines and check them. The
motherboard connectors aren't even close. Thanks for your replies
anyway, guys.
Well, then, given PB's track record, one power supply has two (maybe three?)
connectors to the motherboard, and the other has merely a single connector to a
double row of pins. The former would be the older AT standard power supply and
the latter would be ATX. Both are industry standards which allow for
substitution of non-PB power supplies, as long as the physical form factor is
the same.
For testing purposes, it is often sufficient to attach a generic power supply,
leaving it outside the computer chassis, just to see if the motherboard (and
peripherals) boot up. This approach allows for isolation of a failed component,
either power supply or motherboard... Ben Myers
>> >Thanks
>anyway, guys.
ben_myers_spam_me_not @ charter.net (Ben Myers) wrote in message news:<411f7a6b.852811@news.charter.net>...
> the same.
So, is there any sort of adapter that can allow the AT power supply to
connect to the ATX connector on the motherboard?
Yes, AT-to-ATX adapters are available and also adapters to provide 12v to a
Pentium 4 motherboard, but these are last ditch options. ATX power supplies are
really quite inexpensive... Ben Myers
>> the same.
