G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
My system is
Dell 8250
PIV 2.6 GHz
1.0 gig PC1066 RAM
Radeon 9800 PRO
Two 7800 rpm Hard Drives
One Burner and One Standard CD Drive
One PCI SLOT Cooler
When I boot, my system tells me that "system battery voltage is low" and
sometimes it won't boot. Unplugging the PCI slot cooler or one of the drives
allows for normal boot--most of the time I can boot with everything if I
press F1 after the warning. I believe my power supply is a 250 watt
unit--does anyone have an advice on upgrading? Can a power supply limit the
performance of a PC or does inadequate power simply result in system errors
and failure? Any compatible units I should look into?
Thanks a bunch,
Chalky
My system is
Dell 8250
PIV 2.6 GHz
1.0 gig PC1066 RAM
Radeon 9800 PRO
One PCI SLOT Cooler
Thanks a bunch,
Chalky
