Tom's Hardware > Forum > Graphic & Displays > ATI > Problem: Blank display after fiddling with primary/seconda..
Forum Graphic & Displays : ATI - Problem: Blank display after fiddling with primary/seconda..
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hello!
I have a rather embarassing problem. I think I somehow managed to disable my
primary display and enable the secondary display in ATI Catalyst control
panel while playing around with the multi monitor settings. Since I don't
actually have more than 1 display, the result is that I no longer see
anything once Windows starts up. Is there some way I can reset the display
settings without installing all drivers from scratch using Windows VGA mode
(accessed by pressing F8 during startup in Windows 2000)?
Thanks in advance,
Rasmus
Sponsored Links
Rasmus Paetau wrote:
> Hello!
> my primary display and enable the secondary display in ATI Catalyst
> control panel while playing around with the multi monitor settings. Since
> I don't actually have more than 1 display, the result is that I no longer
> see anything once Windows starts up. Is there some way I can reset the
> display settings without installing all drivers from scratch using
> Windows VGA mode (accessed by pressing F8 during startup in Windows 2000)?
Why don't you just plug the monitor into the secondary display port and
change it back? You should have had a DVI -> VGA adaptor in the box if
required. Another option might be a TV.
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
Reply to Anonymous
What about booting to safemode and changing things back or using, if you
have one, a real recent Sys restore point if nothing else. The other posible
work around is boot to safemode, go to device manger and remove the card.
Reboot and let it reinstall then would be back to basic settings I think.
"Ben Pope" <spam@hotmail.com> wrote in message
news:2jc24sFvvkfbU1@uni-berlin.de...
>> Hello!
>> 2000)?
> Ben
Reply to Anonymous
There are 947 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
