Archived from groups: microsoft.public.windows.networking.wireless (
More info?)
Yes, this is dependant on the AP vendor supporting Roaming; normally
supported and you must have the same SSID and WEP setting configured on both
APs.
Adam Arndt
(Also, when using add-on antennas and 2.4 GHZ amps you must be careful to
not exceed FCC regulations.)(You cannot just go out and buy a 15db gain
Omnidirectional antenna and 2watt amp, and flood 2 square miles in 2.4ghz
radiation)
"Mike" <nomail@nospam.com> wrote in message
news:e%237ea5FOEHA.268@TK2MSFTNGP11.phx.gbl...
> Can you have more than one access point, and roam between them seamlessly
> if
> they overlap?
> "Adam Arndt" <a-adama@microsoft.com> wrote in message
> news:um6c6oFOEHA.3752@TK2MSFTNGP12.phx.gbl...
>> Mike,
>> You have a few options for doing this, you could just upgrade the antenna
> in
>> the AP, you could get a 2.4ghz Amplifier, or you COULD get an extender.
>> www.fab-corp.com has one of the best selection of antannas and amps.
>> Adam Arndt
>> news:eAdurjFOEHA.620@TK2MSFTNGP10.phx.gbl...
>> >I just put our 1st wireless access point into our wired LAN, and it
>> >works
>> > great inside of our building. However, I would like to try to extend
> the
>> > range to some of our outlying warehouses. What are some solutions to
>> > extend
>> > the range of a wireles network. Are there repeaters?
>> > Mike
