VCR Analog Camcorder Problem
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I'm having a problem capturing VHS movies from my VCR. If the vcr is
connected to the tv, the tape plays fine, but when I use the same vcr
to try to capture the video, and then convert it to a dvd, the video
keeps breaking up, and just plain bad. The kicker is, if I connect a
Sony analog camcorder and capture the video, the capture is clean,
using the same setup as with the vcr. I'm using an ati 9600 all in
wonder video card with ati's cable and the cable from the vcr. Why
does the camcorder video play fine, and not the vcr? I hope I'm
explaining this so you can understand. TIA
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 1 Build 2600
System Manufacturer NVIDIA
Processor x86 Family 6 Model 10 Stepping 0 AuthenticAMD ~1837
Mhz
14 answers Last reply
More about analog camcorder problem
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I guess I forgot to mention that these are home videos, taken about 10
    years ago with a VHS Camcorder. There is no copy protection.
    On Thu, 01 Jul 2004 16:46:23 -0500, Bob Kovach <bobk80@adelphia.net>
    >Mhz
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    "Bob Kovach" <bobk80@adelphia.net> wrote in message
    news:tt09e0pb4l7smjvot93csh3330qdb1og2e@4ax.com...
    > Mhz
    Sounds to me like a Macrovision (copy protection) problem.
    http://www.digital-digest.com/dvd/articles/macrovision_software.html
    Never found a solution to that myself!
    Laurence
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    In article <5i39e0dlgn30aki06gq89nmfn6ggjv2pnd@4ax.com>, Bob Kovach <bobk80@adelphia.net> wrote:
    One problem can be that the older VHS camcorders and vcr's use a larger head
    gap on their video heads. Now all you find are 19 micron heads that are more
    optimized for EP recording, and as such do not truely make standard SP
    recordings. So playing back an older tape on a newer deck with a smaller head
    gap isnt always optimum.
    >>Mhz
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Thanks for all the replies, and thanks for letting me know about the
    19 micron heads, GMAN, but would this have anything to do with
    providing a good play back while the vcr is connected to the tv, but
    NOT when the SAME vcr is connected to my ati capture card? Could I
    have some kind of interference problem when connected to the ati cable
    going to the computer? Again, thanks for all the help!
  5. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    could you have a ground loop problem? is everything plugged into the same
    electrical outlet?
    news:e4g9e0lfhd2ppruoln7mplrg76ivuol887@4ax.com...
    head
    more
    head
  6. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Vcr plugged into one outlet on joining wall, while computer is on a
    surge protector on the other wall. All outlets are probably on the
    same circuit.
    On Fri, 02 Jul 2004 02:23:46 GMT, "kilmister" <kilmister@hotmail.com>
    >electrical outlet?
  7. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    try the vcr in the surge protector also.
    news:f4r9e0hssr4fm2432caum6kgitl873ctkc@4ax.com...
    > same circuit.
    same
    > >electrical outlet?
  8. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I used an extension cord and plugged the vcr into an outlet in another
    room, and tried it, and also plugged the vcr into the surge protector,
    and still getting the interference. I took the tape out, and went to
    the vcr attached to our tv, and played the tape with no problems.
    Both vcrs are JVC's, and I've traded places with them, and the one
    connected to the tv was always fine, while the one connected to the
    ATI All In Wonder RADEON was messed up. I'm beginning to lose faith
    in the ATI AIW. Also, I still can't figure out why the Anolog Sony
    video camera, hooked up with the same cables, outputs a clear video
    which I can capture with no problem. Thanks for all the help, and I
    really do appreciate it. I just wish something would work.
    On Fri, 02 Jul 2004 16:22:47 GMT, "kilmister" <kilmister@hotmail.com>
    >> same circuit.
    >same
    >> >electrical outlet?
  9. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    >> same circuit.
    >same
    >> >electrical outlet?
    Don't forget that your videocard and monitor are giving you a much
    higher quality picture at much higher resolution than your TV; also
    that your TV screen is optimised for that TV picture and nothing else.
    Any faults in the picture that are smoothed out by the TV may,
    instead, be emphasised by your card and monitor.
    Try the opposite and use your TV as a monitor. You won't get far
    doing word processing or graphics like that!
    patrickp
    patrickp@5acoustibop.co.uk - take five to email me
  10. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    news:5i39e0dlgn30aki06gq89nmfn6ggjv2pnd@4ax.com...
    <snip>
    ATI has something of a history of oversensitive Macrovision detection, that
    kicks in even on non-commercial tapes, just because it detects some
    imperfections that it misreads as Macrovision copy protection.
    I've certainly had that happen. (And wasted money on a supposed signal
    cleaner from Maplin that didn't help at all).
    Laurence
  11. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Did you find away around it? Any help would be greatly appreciated!!
    On Sat, 03 Jul 2004 14:49:48 GMT, "Laurence Wilmer"
    ><snip>
    >Laurence
  12. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I found that DVD shrink does an excellent job of copying DVDs, but I have
    not found ANY macrovision defeat that works for ATI AIW - although there are
    a lot of them that claim to work.
    Sorry!
    Laurence
    news:9sqde0pugj6dpoc3fdgbevk5mp8tsllgfh@4ax.com...
    > ><snip>
    that
    > >Laurence
  13. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    is the sony video camera plugged into the wall also or running on batteries?
    news:0jpde0lpntlq8toj96cleii7g5spsjj88t@4ax.com...
    > >> same circuit.
    > >same
    > >> >electrical outlet?
  14. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Either way, it doesn't matter. The video is good whether I'm running
    it off the plug in charger/adapter, or running off the battery. I
    keep thinking there's some kind of interference with the vcr, but I
    don't know how to get around it.
    On Sun, 04 Jul 2004 02:54:20 GMT, "kilmister" <kilmister@hotmail.com>
    >> >> same circuit.
    >> >same
    >> >> >electrical outlet?
Radeon Video Camcorders ATI Graphics
