Archived from groups: microsoft.public.windowsxp.security_admin (
More info?)
Gary wrote: Thanks for solving my problem , I had downloaded the same
spyware program from microsoft and had the same result, no firewall and would
not turn on.
used the "netsh.exe winsock reset" on the run program and it solved my
problem of 2 weeks instantly
thanks again.
"Torgeir Bakken (MVP)" wrote:
> Joe wrote:
> > When I try and enabling the firewall on my computer I get the
> > message: "Windows cannot start the windows firewall/Internet
> > Connection Sharing service." What is wrong??
> > I recently downloaded the Beta version of Microsoft Anti Spyware.
> > I ran the tool and remove a bunch of files that appeared bad.
> Hi
> If you don't have WinXP SP2 installed, try this one:
http://www.spychecker.com/program/winsockxpfix.html
> Please try this if you have SP2 for WinXP installed:
> Start/Run --> cmd.exe
> and then, in the command prompt that opened up, type:
> and hit Enter. Follow prompts and reboot.
> If that didn't work, see if registering the following DLLs helps:
> From Start/Run, run the following commands:
> regsvr32 %windir%\system32\atl.dll
> then
> regsvr32 %windir%\system32\hnetcfg.dll
> regsvr32 %windir%\system32\netshell.dll
> regsvr32 %windir%\system32\netcfgx.dll
> regsvr32 %windir%\system32\netman.dll
> Then do a reboot.
> torgeir, Microsoft MVP Scripting and WMI, Porsgrunn Norway
> Administration scripting examples and an ONLINE version of
> the 1328 page Scripting Guide:
http://www.microsoft.com/technet/scriptcenter/default.mspx
