Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hope someone can help,
I've just bought a 2ndhand Hercules 9700 and it came without any cables. I
have a standard 4pin svhs cable that works but the picture is almost devoid
of colour. I've also tried a cable from my old Sapphire 9100 and that shows
a picture thats very dark and saturated with colour. The Sapphire cable has
8 pins
o o o
o o o
o o ----- these 2 are instead of the plastic block
If you have the same card can you check the pin configuration of the cable
and tell me whats its like - i may be able to adapt my Sapphire cable to
suit.
TIA
Ben
8 pins
o o o
o o o
suit.
TIA
Ben
