Archived from groups: alt.comp.periphs.videocards.ati (
More info?)
http://www.jscustompcs.com/power_supply/
I think that the above might be simplified a little too much, but it may be
helpful.
(Guessing at the number of drives you have, I get about 350W for a 3200 +
system with a 9800 non-XT.)
The following is an ancient article (from January, 2000), but you may find
it interesting in a general sense:
http://www.anandtech.com/showdoc.html?i=1128&p=1
(It shows that for the original Athlons, a good 300W supply gave better
reliability than a poor 400W supply.)
Antec supplies still seem to be highly regarded, although they are not
inexpensive. I'm currently using a 420W supply from Thermaltake, which I
bought a few months ago for less than $50US. Its fan is the quietest one in
my system, even though it's not adjustable.
I don't have the experience to recommend strongly for (or against) any
particular make. The only PS that I've ever had fail in service was on my
first PC clone, a Dell Dimension XPS P133c bought in the autumn of 1995.
Fortunately, the PS didn't self-destruct until well after I'd already handed
the machine down to my nephew. (A lot of people like to hate Dell, but the
main weakness I've seen in their systems is weak power supplies. The problem
was compounded because Dell used nonstandard wiring, so it wasn't easy to
swap in an industry-standard PS. I don't know if Dell still uses the dreaded
separate 3.3V connector.)
HTH.
Address altered. Replace nkbob with bobkn.
"Steve" <bond_youknowtherest_uk@yahoo.com> wrote in message
news:2m8gjoFjkro1U1@uni-berlin.de...
> If I put a 3200+ Athlon XP and a Radeon 9800Pro into my current PC I need
to
> upgrade my 250watt PSU, what do I need, 400Watt?
> Thanks,
> Steve
