Tom's Hardware > Forum > Systems > Packard Bell > PC problem - Need help
Forum Systems : Packard Bell - PC problem - Need help
Archived from groups: alt.sys.pc-clone.packardbell (More info?)
I have a Gateway PC 800MHz P3 inside....'and a problem maybe.
Every time I press the button on the base to turn the machine ON, the light
on the front comes on and it makes the usual sounds, but after 2 or 3
seconds, it switches itself OFF.
It just keeps doing this until I take the plug out at the back for app., 10
seconds and re-insert it.
Then it does the same routine as described all over again.
Can anyone help me with this?
Thanks.
Geo.
Sponsored Links
Weird! It all seems to be working fine now (I hope!), but all I did was to
follow the wires from the switch on the front of the base to where it plugs
into the mobo....'then I disconnected this plug for a few seconds and
re-connected it.
The PC fired up right away! Anyone have any explanations for me as to what
might have caused all this?
Is it significant in anyway? Would this indicate a fault?
Thanks.
Geo.
"Eos" <FreeSoft@(SkipTheBrakets)Tiscali.co.uk> wrote in message
news:eDsrd.61051$F7.25937@fe1.news.blueyonder.co.uk...
> light
> 10
> Thanks.
> Geo.
Reply to Anonymous
news:sWtrd.61108$F7.50882@fe1.news.blueyonder.co.uk...
> was to follow the wires from the switch on the front of the base to
> where it plugs into the mobo....'then I disconnected this plug for a
> few seconds and re-connected it.
> to what might have caused all this?
> Thanks.
> Geo.
>> the light
>> 3
>> app., 10
>> Thanks.
>> Geo.
Hey Geo:
Your in the wrong newsgroup. you want news:alt.sys.pc-clone.gateway
not Packard Bell.
However it can be a simple wrong wiring from the switch to the
motherboard connections or part of the motherboard is touching metal
at the base and it is shorting out.
Elector
Reply to Anonymous
"Elector" <elector@my-deja.com> wrote in message
news:BLCrd.42897$AL5.28234@twister.nyroc.rr.com...
>> to follow the wires from the switch on the front of the base to where it
>> plugs into the mobo....'then I disconnected this plug for a few seconds
>> Thanks.
>> Geo.
>>> light
>>> 10
>>> Thanks.
>>> Geo.
> Hey Geo:
> Your in the wrong newsgroup. you want news:alt.sys.pc-clone.gateway not
> Packard Bell.
> However it can be a simple wrong wiring from the switch to the motherboard
> connections or part of the motherboard is touching metal at the base and
> it is shorting out.
> Elector
Thanks Elector! I tend to go with 'your' explanation as all I did was
diconnected and reconnect the plug between mobo and front switch on the
base.
BTW....'I don't think the guys in the Gateway NG are talking to me! I did
post, but no replies.
Cheers.
Geo.
Reply to Anonymous
- 0 +
news:r7Ird.64069$F7.45688@fe1.news.blueyonder.co.uk...
>>> Thanks.
>>> Geo.
>>>> light
>>>> app., 10
>>>> Thanks.
>>>> Geo.
>> Hey Geo:
>> Packard Bell.
>> motherboard connections or part of the motherboard is touching metal at
>> Elector
> base.
> Cheers.
> Geo.
Yes Geo. I believe Mr. Elector and Ken covered the full basis of your
problem.
On many systems the power supply could be as Ken stated (on its way out).
This of course will depend on how old or how under utilized the computer is.
As Mr. Elector & Ken stated, there could also be a metal on metal situation
that can cause that short. The suggestion of the power plugs being loose or
the wire frayed could also be a major point of looking into. On the
motherboard as Mr. Elector stated the pins and the cable could have been
loose and your reseating them fixed your situation.
I know that Elector and Ken did not mind assisting you in this group.
Have a Happy Holiday..!
W.
Reply to winston
"Winston" <winston@dsn.security.net> wrote in message
news:41af5efa$1_3@127.0.0.1...
>>> Thanks.
>>> Geo.
>>>> light
>>>> app., 10
>>>> Thanks.
>>>> Geo.
>> Hey Geo:
>> Packard Bell.
>> Elector
> base.
> Cheers.
> Geo.
>problem.
>.On many systems the power supply could be as Ken stated (on its way out).
>is.
Good summary. Let's hope Eos' conclusion is a happy one!
Cheers and Happy Holidays!
Reply to Anonymous
<snip>
> was diconnected and reconnect the plug between mobo and front switch
> on the base.
> I did post, but no replies.
> Cheers.
> Geo.
Ha ha loved that last statement about the Gateway group :-)
I am glad it all worked out for you.
Come back anytime, and you are more than welcome.
Elector
Reply to Anonymous
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
