Terrible spyware problem
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
Hi, I am having a terrible spyware problem. Things like dyfuca and IST and
1800 searchassistant are constantly on my computer. I am running ad-aware,
and it says it takes it off, but when i go into the program files, boom there
this stuff is. Also, upon leaving the system "clean" and logging off to
another or even the same profile, I have run ad-aware again and it is back.
Is there a file or files that are deeply imbedded allowing this stuff to come
back on?? and if so, how do I get rid of it?
11 answers Last reply
More about terrible spyware problem
  1. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    You need more that just Adaware..
    First step is to run a one shot virus remover.. I have found that McAfee
    Stinger works for people.. download and run it..
    http://vil.nai.com/vil/stinger/
    You will also need to download some more Spyware removal software.. Spybot
    is available at this website.. don't forget to check for updates after you
    have started it..
    http://www.safer-networking.org/en/index.html
    Spybot has the ability to immunize a system, but there is better for this
    function, so download and run Spyware Blaster too.. again, check for
    updates..
    http://www.javacoolsoftware.com/
    If you have had your Internet browser hijacked, that is to say, you get
    redirected through a search engine NOT of your choosing, you will need
    different tools..
    HijackThis is a popular and effective tool.. download it from here..
    http://www.spychecker.com/download/download_hijackthis.html
    CWShredder will eliminate CoolWebSearch and variants.. there is a free
    download here..
    CWShredder.. http://www.intermute.com/spysubtract/cwshredder_download.html
    For other tools in the fight against spyware, visit this website and
    bookmark it..
    http://www.pchell.com
    You must also run a firewall and anti-virus program.. here are some links
    for you..
    http://www.mcafee.com .. http://www.symantec.com .. http://www.zonealarm.com
    ... http://www.kerio.com .. http://www.gate.com .. http://www.avast.com ..
    http://www.grisoft.com..
    Please return to this thread and provide feedback.. it is the only way that
    helpers here can determine how effective the advice given has been..
    Good luck..
    Mike Hall
    MVP - Windows Shell/user
    http://dts-l.org/goodpost.htm
    "willow" <willow@discussions.microsoft.com> wrote in message
    news:E7DFEF23-D29B-4146-B93A-6870A08895AC@microsoft.com...
    > and
    > ad-aware,
    > there
    > back.
    > come
  2. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Just so you know, I do have Norton Antivirus . I also did download the
    spybot, but i also got 2 viruses from it. I will try the other things
    though. Thanks, crossing my fingers.
    > have started it..
    > updates..
    > different tools..
    > download here..
    > bookmark it..
    > for you..
    > Good luck..
    > Mike Hall
    > > and
    > > ad-aware,
    > > there
    > > back.
    > > come
  3. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Spybot Search and Destroy couldn't possibly give you a virus! Maybe if you
    downloaded it from a 3rd party site!
    Peter.
    Toronto, Canada.
    Windows XP Home SP2.
    P4 dual HT @ 3.0ghz, 160gb HD, 1.0gb DDR.
    news:C26B49AE-81FE-4ED9-855F-C529FEF20E94@microsoft.com...
    >> Spybot
    >> you
    >> have started it..
    >> updates..
    >> different tools..
    >> download here..
    >> CWShredder..
    >> bookmark it..
    >> for you..
    >> that
    >> Good luck..
    >> Mike Hall
    >> > and
    >> > ad-aware,
    >> > there
    >> > to
    >> > back.
    >> > to
    >> > come
  4. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    1) Download the following three items...
    Trend Sysclean Package
    http://www.trendmicro.com/download/dcs.asp
    Latest Trend Pattern File.
    http://www.trendmicro.com/download/pattern.asp
    Adaware SE (free personal version v1.05)
    http://www.lavasoftusa.com/
    Create a directory.
    On drive "C:\"
    (e.g., "c:\New Folder")
    or the desktop
    (e.g., "C:\Documents and Settings\lipman\Desktop\New Folder")
    Download Sysclean.com and place it in that directory.
    Download the Trend Pattern File by obtaining the ZIP file.
    For example; lpt406.zip
    Extract the contents of the ZIP file and place the contents in the same directory as
    sysclean.com.
    2) Update Adaware with the latest definitions.
    3) Disable System Restore
    http://vil.nai.com/vil/SystemHelpDocs/DisableSysRestore.htm
    4) Reboot your PC into Safe Mode and shutdown as many applications as possible
    5) Using both the Trend Sysclean utility and Adaware, perform a Full Scan of your
    platform and clean/delete any infectors/parasites found.
    (a few cycles may be needed)
    6) Restart your PC and perform a "final" Full Scan of your platform using both the
    7) Re-enable System Restore and re-apply any System Restore preferences,
    (e.g. HD space to use suggested 400 ~ 600MB),
    8) Reboot your PC.
    9) Create a new Restore point
    * * * Please report your results ! * * *
    Dave
    http://www.claymania.com/removal-trojan-adware.html
  5. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Try the antispyware program from micorsoft beta. Its a version of giantsoft.
    Get it from the main microsoft site from the security center. A note not all
    spyware and antivirus progs pick up and find everything. And now said
    parasites are better at hiding. You could try an online virus scanner like
    norton or trend micro these have some antispyware removes in them. Well in
    the installed progam on disc.
    > Create a directory.
    > On drive "C:\"
    > or the desktop
    > sysclean.com.
    > 8) Reboot your PC.
    > Dave
  6. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    HI guys, well I am on my computer at work, because last night I did
    everything you all had said to do. It ran all night!! Any way, the sysclean
    package does find the problems, but reports error and can not clean or move
    the files it has identified as viruses. I am not happy. Kids are not happy.
    I guess all I can do now is take it to someone. But, wouldn't they do
    exactly what you all told me to do?? Also, If and when we get it off, I
    guess there ar no gusrantees that it will never come back right??
    > > Create a directory.
    > > On drive "C:\"
    > > or the desktop
    > > sysclean.com.
    > > 8) Reboot your PC.
    > > Dave
  7. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    There are no guarantees !
    You have to practice Safe Hex and teach those habits to the family. You need to have an
    active FireWall and an active Anti Virus defense. That will mitigate your possibilities of
    re-infection.
    You can email me the SYSCLEAN.LOG and we can determine a course of action from there. Just
    remove ~nospam~.
    Dave
    news:E392B2A2-2CD5-486A-8F91-6E1BEA0045F1@microsoft.com...
    | > > Create a directory.
    | > > On drive "C:\"
    | > > or the desktop
    | > > sysclean.com.
    | > > 8) Reboot your PC.
    | > > Dave
  8. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Hi thank you to all who gave me your input. I have now downloaded pccillin
    and it found the viruses (trojans) and removed them, however I am still
    experiencing files that I have deleted miraculously appearing again. Like
    adservice and such. They are so sneaky!!!
    > re-infection.
    > remove ~nospam~.
    > Dave
    > | > > Create a directory.
    > | > > On drive "C:\"
    > | > > or the desktop
    > | > > sysclean.com.
    > | > > 8) Reboot your PC.
    > | > > Dave
  9. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Go to www.lavasoft.de and download Ad Aware SE. It's free, and it is
    the best tool for exterminating this particular type of crudware.
    Ken
  10. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Adaware SE should remove "adservice".
    Dave
    news:2ABB48FC-5DDB-49FF-982A-17DC948FADCA@microsoft.com...
  11. Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
    Willow
    If you run the software or visit the site that deposited these 'baddies' on
    your system, there is a good chance that some will revisit..
    Mike Hall
    > pccillin
    >> need to have an
    >> re-infection.
    >> remove ~nospam~.
    >> Dave
    >> sysclean
    >> move
    >> happy.
    >> I
    >> giantsoft.
    >> not all
    >> like
    >> Well in
    >> | > > Create a directory.
    >> | > > On drive "C:\"
    >> | > > or the desktop
    >> same directory as
    >> | > > sysclean.com.
    >> Full Scan of your
    >> preferences,
    >> | > > 8) Reboot your PC.
    >> | > > Dave
    >> and IST and
    >> ad-aware,
    >> files, boom there
    >> off to
    >> it is back.
    >> stuff to come
Microsoft Spyware Windows XP
