Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi,
Using MMC 9.1 with a AIW 9800 Pro, Cat 4.6 on WinXP Pro.
When I create a profile to capture in AVI, I set the video codec to YUY2
from the drop down list and click Finish. If I go directly back in, look
at the codec selected, it reverts back to UYVY <native>. If I do the
same as above, but set Huffy, the codec stays listed as Huffy. I also
tried YV12, but it too doesn't stay and gets replaced by UYVY <native>.
I need either YV12 or YUY2 for a AviSynth script to work and I don't
understand if these codecs are listed why I can't select them and have
them stay selected.
Oh, great.
And then to add salt to the injury, MMC just locked up and now will not
End Process in Task Manager.
<puts post on hold>
I restarted XP and when XP came back up I tried to run TV again. It
brings up the TV splash screen, then dies. FFFFFFFFFFFFFFFFFFFFFFFk!
I re-run the MMC setup in repair mode. Okay, try to run it again, crash
and again quites.
Run test and it says the capture drivers are not installed! Yeah, right.
I guess I was just imagining the capture I was just working on before
the MMC locked up. So when MMC crashes, it commits driver suicide.
So I re-run the Cat 4.6 driver pack and select only the WDM driver, and
re-install the capture driver. Now it is working again.
Oh, great.
That mysterious ATI Device Detection icon is back in the system tray.
Has anyone ever figured out what atidtct.exe is for? I know it can be
removed.
Sorry, hasn't been a very good day.
Mark
Hi,
them stay selected.
Oh, great.
<puts post on hold>
and again quites.
Oh, great.
removed.
Mark
