Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
KB885250 is causing problems when files or applications are shared from
Windows 95/98/Me machines. In the case of our DOS multi-user database
application, if the application and data reside on a 95/98/Me machine, a user
on XP that has this security update installed is not allowed to create any
files from the application on the host machine.
This is a major problem, and the only solution I have at this point is to
have users uninstall this update.
Is anyone aware of a way to install the update and change something that
will allow shared files and applications on 95/98/Me machines to function
properly?
Thanks
> from Windows 95/98/Me machines. In the case of our DOS multi-user
> database application, if the application and data reside on a 95/98/Me
> machine, a user on XP that has this security update installed is not
> allowed to create any files from the application on the host machine.
> to have users uninstall this update.
> that will allow shared files and applications on 95/98/Me machines to
> function properly?
> Thanks
Here's information I found provided by another MVP:
KB885250, an update from 2/8/2005 can cause file and printer sharing
problems under Windows networking and SAMBA.
XP SP2 clients seem unaffected, the issue surfacing for XP SP1 clients
with this hotfix applied. If your attempt to use SMB shares seems
compromised after last week's hotfixes, remove KB885250.
See this MS Knowledge Base article:
http://www.microsoft.com/technet/s [...] 5-011.mspx
Check in the section "Vulnerability Details, Workarounds" for several
approaches to providing the protection of the hotfix without using the
hotfix.
Malke
MS MVP - Windows Shell/User
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
Archived from groups: microsoft.public.windowsupdate,microsoft.public.windowsxp.general,microsoft.public.windowsxp.network_web,microsoft.public.windowsxp.security_admin (More info?)
No, xp sp2 is ALSO affected by serious networking problems if 885250 is
installed; the files in random folders become inaccessible, among other
issues--and this is true even on networks consisting only of windows xp sp2
machines.
"Malke" <noreply@invalid.com> wrote in message
news
bppIOFFFHA.624@TK2MSFTNGP09.phx.gbl...
>> function properly?
>> Thanks
> hotfix.
> Malke
> "Don't Panic!"
> is installed; the files in random folders become inaccessible, among
> other issues--and this is true even on networks consisting only of
> windows xp sp2 machines.
Thanks, Manuel. I'll change my notes accordingly. I have to go on what
others have reported since I haven't had any problems with that update
personally on any of the XP boxen (all SP2) and haven't had any
problems with interoperability with Samba on the Linux boxen.
I appreciate the update.
Malke
"Don't Panic!"
I had other issues in my work environment. My Windows 2000 Professional SP3
admin workstation BSOD'ed after applying the latest round of security
updates. Looking at the updated file lists I suspect that the KB885250 was
the culprit. Replacing .SYS files means potentially affecting the boot
environment. I couldn't get my workstation into Windows by using any of the
Safe Modes or using the Last Known Good Configuration option. Had to wipe it
out and reinstall from scratch.
Looks like this KB885250 update might be *almost* as catastrophic as the
infamous Windows NT 4.0 SP6, which broke TCP/IP. Hence the rush release of
SP6a. Glad that I tested the 2/2005 updates on my own workstation before
rolling them out companywide!
> Malke
> "Don't Panic!"
Yes! I have also experienced this problem (search this NG for other 885250
posts).
The strange this is, I've only experienced this on AMD machines. I applied
the update to all my XP-2 machines at work (Intel), and everything was fun.
But at home, all machines are AMD, and the randomly (but consistent)
dissappearing files problem is at hand...
"Manuel Lopez" <manuel.email.at.post.harvard.edu@deadspam.com> wrote in
news:37imk6F5974i8U1@individual.net:
> news
Hi, I'm also having problems with that kb885250 update.
My WinXP "automatic update" installed the recent Feb. 8th Windows XP
updates, including "Security Update for Windows XP (KB885250)." After
that, I was unable to use "save as..." in either Excel or Word to
rename documents from several WinXP's to a Win98 computer I use as a
file server. Eventually I tracked the problem down to the recent
updates, and then to kb885250. By removing that update, 42 computers in
my school using WinXP Pro were fixed (talk about having evidence!).
Unfortunately, on one computer that I had been experimenting with, I
used "System Restore" to roll back to Feb. 7th, prior to my discovery
of the problem with kb885250. So now, that computer actually has the
kb885250 update installed on it, with its attendant repercussions, but
the update doesn't show in "Add/remove programs" nor in the
"Installation History" on the Win Update page. I tried installing and
then uninstalling the update, sifting through the registry, etc., but
to no avail. My quandary is, how do I uninstall something that the
computer thinks is -already uninstalled-?
FrankDC
FrankDC's Profile: http://www.iamnotageek.com/member.php?userid=10155
View this thread: http://www.iamnotageek.com/showthread.php?t=817058
We have a P2P network using a Win 98 machine to store files.
From our XP SP2 workstations we cannot 'save as' using a new filename
on the Win 98 share with KB885250 installed.
I spent a couple of hours trying to find the problem on the first
workstation to be affected when the user told me she had clicked the
Update icon before going to lunch, the problem appeared after lunch.
Ten updates had been installed on this machine on the day. I
uninstalled them all and re-installed one at a time to find the
culprit.
Thanks Bushy, that's how I tracked it down too (but not that quickly!)
The problem is that one of the computers I messed with now has the
kb885250 installed, but because I ran "System Restore" while
experimenting, the kb885250 doesn't show up in the add/remove list. So
now I'm trapped with the update installed and messing up the file
saving, but no obvious way to uninstall it. What a mess!
FrankDC
Archived from groups: microsoft.public.windowsxp.network_web,microsoft.public.windowsxp.security_admin (More info?)
Unfortunately, apparently MS won't fix this, at least according to one rep.
See this post from another thread:
"Jeffrey" <Jeffrey@discussions.microsoft.com> wrote in message
news:579D3D8F-B7DD-46C5-B430-19C2947EF707@microsoft.com...
> Here is part of the reply Microsoft provided:
> "I fully understand the inconvenience of this issue. However, I am afraid
> that there will not be a hotfix for this issue. "
> I suggest sending as many messages as possible in complaint over this as
> they have effectivly made network drives useless with no intention to
> correct
> the problem.
That's strange. How can there not be a hotfix if it breaks networking on so
many computers and all versions of windows (however, one poster says only
amd machines are affected--I haven't tested with intel)? I would expect
there to be a lot of complaints from customers, corporate and otherwise,
once they realize the problem (and the cause).
Let me know where you submitted your query/complaint on this, and I'll send
another.
Hi Manuel, Thanks for the notes. I will also submit a complaint. It's
clearly a problem, and not just related to amd boards; we have Gateways
with Intel at my job and it messed up 42 machines running WinXP Pro. In
the meantime, I've had to uninstall it and hide the hotfix, not a great
solution but at least a workaround.
-Frank DC
FrankDC
We have two computers at work on a peer-to-peer network (Intel not AMD).
Because of Automatic Updates, KB885250 was installed and we had the
"Save A" problem in Word/Excel. After removing the update through
Add/Remove Programs everything was fine. As expected though, overnight
the Update was reinstalled. Frank mentioned "Hiding" the update. How
do I do that in order to keep this update from reinstalling (I don't
really want to stop using Auto Updates).
PHanson
PHanson's Profile: http://www.iamnotageek.com/member.php?userid=10245
please note this post from the other thread on where to report this bug:
news:CE8857D8-3001-4EE1-9447-DA0D45BB9007@microsoft.com...
>I places an email support request for Windows XP SP2 at
> http://support.microsoft.com/oas/d [...] prid=6794&
> In their latest responce they suggested I send in a feature request to the
> Microsoft Wishlist, so I sent a request there also that they fix update
> KB885250 (Removing this one also removes the proble). Since my company
> doesn't carry any Intel I haven't been tested with those either. I'm
> hoping
> that they are not truly understanding what their update did. With wishlist
> addesss is mswish@microsoft.com. For reference the support person that
> gave
> me the responce that there would be no hotfix is Martin Ma
Thanks, I'll report it to ms at those websites as a critical/severe bug:
kb885250 arbitrarily prevents access to some but not all shared folders on
properly configured windows xp sp2 and other windows networks, both
peer-to-peer and client/server.
(It may be that only people using netbios, i.e. non-dns style, names are
seeing it, but that still makes it a widespread problem. Despite what that
rep said, I assume they'll withdraw or fix kb885250 over the next few weeks
as the complaints increase and the cause is tracked down.)
I discovered something very interesting about the Feb 8th kb885250 security
patch bug (where it arbitrarily makes files on certain shared folders
invisible). If the problem folder is renamed, the files appear and
disappear depending on the length of the rename; however, it is hard to
discern a pattern:
Example: These are all folders under the share \\main\c\archive\
Files become INVISIBLE:
asante.firmware\firmware.v_2.5
asante.firmware\firmware.v_2.9
asante.firmware\firmware.v_3.5
asante.firmware\firmware.v_a.b
asante.firmware\firmware.vca.b
asante.firmware\firmware._
asante.firmware\12345678901234
asksam
asksam___ [3 underscore]
asksam____ [4 underscores]
utils
utils2
utilsa
utils____ [4 underscores]
Files become VISIBLE:
asante.firmware\firmware.2.5
asante.firmware\firmware.v_2.50
asante.firmware\firmware.v_2.5.t
asante.firmware\firmware.v_2.5.test
asante.firmware\123456789012345
asksam_ [1 underscore]
asksam__ [2 underscores]
asksam_____ [5 underscores]
utilsoth
utilsab
utils25
utils250
utils__ [2 underscores]
utils___ [3 underscores]
"FrankDC" <FrankDC.1kwuur@no-mx.forums.iamnotageek.com> wrote in message
news:FrankDC.1kwuur@no-mx.forums.iamnotageek.com...
> FrankDC
In my case, I first noticed this because I bought a new computer, and was
transferring my logs from my old computer to the new one (fresh install of
XP-2 slipstream + recent updates that include the dreaded 885250)
Here is an example of an "invisible" filename:
\\olympia\c$\Documents and Settings\shenan.INTROVERTED\My Documents\Logs\ICQ
\Chats\Chats.rar
Other files in that folder do appear, but not that particular one. I CAN
however manually type in the complete filename to get to the file, it just
does not show up in explorer (nor does it copy over when copying from the
root folder which contains it)... :-(
Hi, I received the following reply from MS Tech Support concerning this
issue, FYI:
Thank you for contacting Microsoft Online Support Service. My name is
Vivian, and I'm glad to work with you.
From your description, I understand that after installing the update
885250, you could not use the Save As option via Word and Excel to save
the files to the Windows 98 SE computer. Then you removed and blocked
this update, and the issue was resolved.
I am sorry for all the inconveniences you've experienced.
We would like to thank you for bringing this issue in to our attention.
Your time and effort on this matter is appreciated. Microsoft is
continuing to improve itself and we strive to provide improved products
for our users. We do appreciate having users like you who stand closely
with our products and always provide such great feedback. It is your
efforts help to make our product powerful and easy to use. This
particular issue has been reported to our development team and they are
currently investigating possibilities for inclusion.
Thank you for your suggestion. If there is any new update for MS05-011,
I will share it with you.
If anything above is unclear, please do not hesitate to let me know.
It's my pleasure to be of assistance.
Best regards,
FrankDC
I have experienced issues with this update too and have uninstalled it
from company XP machines. I'm applying anything relevant from the
vulnerability workarounds until (if?) it is addressed by Microsoft.
However, my circumstances are different in that we run an Appleshare
6.3 server (SMB based) which ceased being browsable, even though
authentication seemingly takes place normally.
Also, I was still able to access my SMB shares as usual on our Debian
Linux servers (smbd 2.2.3a-14.1) with KB885250 installed so I imagine
the Linux/Unix interoperability issues are fairly build/distro
specific.
> uninstalled it
> the
> Microsoft.
> Appleshare
> though
> Debian
> imagine
> specific.
I operate and maintain a couple of local area networks and we have
been having this problem. After researching I had also come accross
this issue of KB885250 update. After uninstalling this update all
computers accorss the network were able to once again browse all
files.
Why Microsoft will not fix this I’m not sure, but I think everyone
should file a formal complaint as this is un-acceptable to anyone
using a computer network.
Thanks
Jason
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Secur [...] 65906.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=870279
On Wed, 23 Feb 2005 09:23:53 -0500, FrankDC
I had this same problem as a result of deleting the
C:\Windows\$NtUninstallKB885250$ directory. I could neither uninstall
it or reinstall it and then uninstall it.
However, I have another pc with the same OS - XP+SP2 - and file
structure on which I hadnt deleted the
C:\Windows\$NtUninstallKB885250$ directory so simply copied the whole
directory across and uninstalled it using spuninst.exe which is in
that directory's tree.
This worked (fingers were tightly crossed) and 885250 successfully
removed.
John
X-Signature: Effluent
***IMPORTANT***
Please do not reply to effluent@blueyonder.co.uk
This is an antispam address.
Please replace effluent with archway.
Call Microsoft to get hotfix 895900 this information is listed on:
http://support.microsoft.com/?kbid=885250 there is a link pointing to 895900
http://support.microsoft.com/kb/895900/
Garyp@tksol.com
> properly?
> Thanks
Gary,
Thanks so much for your post. I spent hours with Microsoft both on the
phone and in repeated emails just trying to get them to acknowledge the
problem.
FYI, the issue with KB885250 also affects Snap Servers since they use
the same method of SMB. Snap's (Adaptec's) response was totally
unacceptable (asking users to buy a $699 OS upgrade per server!)
http://adaptec-tic.adaptec.com/cgi [...] MQ**&p_li=
Great to see this issue will finally be fixed by Microsoft. I imagine
KB895900 will undergo more testing and then finally replace the
defective KB885250.
Again, thanks for helping the user community by posting this
information.
895900
> Garyp@tksol.com
Hello Manuel Lopez,
I have been fighting this problem for several of my clients, I found a
hotfix that did not work, I still have the problem and I have also tested
this from a CMD prompt and here is my results.
When I isssue a "Dir" command by itself it reports no files or folders.
if I issue a "dir *.exe" I can see all the executables.
I have opened a ticket with MS and when they resolve the issue I will update
this post.
Garyp
Z:\2003 Resource Kit>dir
Volume in drive Z has no label.
Volume Serial Number is AAAA-AAAA
Directory of Z:\2003 Resource Kit
File Not Found
Z:\2003 Resource Kit>dir *.exe
03/22/2005 07:13 AM 12,337,752 en_windows_server_2003_reskit.exe
03/30/2005 02:35 PM 392,552 q329357_WXP_SP1_x86_ENU.exe
03/30/2005 11:46 AM 12,337,752 rktools.exe
03/18/2005 08:55 AM 4,934,480 WindowsXP-KB838079-SupportTools-ENU.exe
4 File(s) 30,002,536 bytes
0 Dir(s) 49,053,638,656 bytes free
> machines.
> news
> >> function properly?
> >> Thanks
> > hotfix.
> > Malke
> > "Don't Panic!"
Thanks for your note. I'm waiting for xp sp3 to fix the problem (I assume
it will be fixed by then), and have removed kb 885250 from my systems and
also hidden it from appearing on windows update.
"Garyp" <grp@tksol.com> wrote in message
news:649306C7-555E-471B-9892-74038105E32B@microsoft.com...
> Hello Manuel Lopez,
> update
> this post.
> Garyp
> File Not Found
>> sp2
>> machines.
>> news
>> >> function properly?
>> >> Thanks
>> > hotfix.
>> > Malke
>> > "Don't Panic!"
MS have at last acknowledged some of the problems with this hotfix.
Go to
for details of another patch to fix the problem - if their comments apply.
Sounds like a new hotfix is on the way from Win Update
> > Hello Manuel Lopez,
> > update
> > this post.
> > Garyp
> > File Not Found
> >> sp2
> >> machines.
> >> news
> >> >> function properly?
> >> >> Thanks
> >> > hotfix.
> >> > Malke
> >> > "Don't Panic!"
Go to
for another patch to fix the problem - if their comments apply. Sounds
It was unusually troublesome:
http://www.eweek.com/article2/0,1759,1815956,00.asp
"bushy" <bob@58bf.freeserve.co-dot-uk.no-spam.invalid> wrote in message
news:MJKdnXsvyu2B8fPfRVn_vQ@giganews.com...
> Go to
Like everyone else I have problems with the update to.
Here is what we have found out
All Windows XP machines service Pack 2 with all updates are having
problems with a Intel network card.
Windows XP machines without Intel cards and all patched up are good and
running fine.
Can anyone tell me if it is Intel cards only or any other we have many
Broadcom cards that are running fine.
Rodney Shoffstall
rshoffstall
rshoffstall's Profile: http://www.iamnotageek.com/member.php?userid=12847
I'm running into this problem pretty heavily in cases where we have XP SP1
and 2 machines writing to win 98 machines acting as servers on peer-to-peer
servers. I support a particular product that runs an InstallShield session
from the server to the client- the big problem we're running into is 1607
errors (unable to install InstallShield scripting runtime). Anyone know if
the hotfix that fixes this problem works on this type of issue? So far the
only solution we've had is to remove KB885250- I'm not sure if the fix that
MS has put out for the writing error will affect executables coming FROM the
server. I don't want to start implementing an unstable fix unless I know it
will work.
> properly?
> Thanks
There are 607 identified and unidentified users. To see the list of identified users, Click here.
