Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
Hi,
For the last few days I have been routinely getting pop-ups when starting IE
and during my net session. They are general ads, not the Messenger Service
type. I have SP2 with the IE blocker set to the highest level, and also have
a Google Toolbar blocker as a second line of defense. These blockers were
very effective until about 3 or 4 days ago.
I don't recall downloading any software prior to this. I have Spybot Search
and Destroy and AVG anti-virus software, which I routinely run.
Any advice would be appreciated.
Thanks,
James
Sponsored Links
semajbar wrote:
> Hi,
> starting IE and during my net session. They are general ads, not the
> Messenger Service
> also have
> were very effective until about 3 or 4 days ago.
> Search and Destroy and AVG anti-virus software, which I routinely run.
Even though you already have Spybot, follow these malware removal steps
anyway. Step 1 doesn't apply, but can't hurt. It is crucial that you do
everything with updated tools in Safe Mode.
1) Scan in Safe Mode with current version (not earlier than 2004)
antivirus using updated definitions.
Before you remove malware, get LSPFix (or WinSockFix for XP which you
can get from MajorGeeks) - see links below.
2) Remove spyware with Spybot Search & Destroy and Ad-aware. These
programs are free, so use them both since they complement each other.
There is a new version of CWShredder from Intermute. I would not
install the other Intermute programs, however. Alternately, there are
CoolWebSearch malware removal steps at SilentRunners.
Be sure to update these programs before running, and it is a good idea
to do virus/spyware scans in Safe Mode. Make sure you are able to see
all hidden files and extensions (View tab in Folder Options).
If the malware remains even after you used Ad-aware and Spybot, you can
scan with HijackThis. HijackThis is an excellent tool to discover and
disable hijackers, but it requires expert skill. See below for
HijackThis links, including sites where you can post your HJT logs. A
combination of HijackThis and About:Buster works well in removing the
About:Blank homepage hijacker. Again, this is an expert tool and
novices should get help with it.
3) If you are running Windows ME or XP, you should disable/enable System
Restore after the system is clean because malware will be in the
Restore Points. With ME, you must disable System Restore completely.
With XP, you can delete all but the most recent (presumably clean)
System Restore point from the More Options section of Disk Cleanup
(Run>cleanmgr).
4) Make sure you've visited Windows Update and applied all security
patches. Do not install driver updates from Windows Update.
5) Run a firewall.
Links to help with malware:
Software/Methods:
http://www.safer-networking.org - Spybot Search & Destroy
http://www.lavasoftusa.com - Ad-aware
http://www.majorgeeks.com - good download site
http://www.intermute.com/spysubtra [...] nload.html
http://www.silentrunners.org/sr_cwsremoval.html. - SilentRunners
http://www.cexx.org/lspfix.htm - Repair Winsock 2 settings after
removing spyware
http://www.spychecker.com/program/winsockxpfix.html - WinsockXPFix.exe
HijackThis:
http://www.aumha.org/a/hjttutor.htm - HijackThis tutorial by Jim
Eshelman
http://aumha.net - forums
http://spywarewarrior.com/viewforum.php?f=5 - Spyware Warrior HijackThis
forum
http://www.wilderssecurity.com/
http://forums.tomcoyote.org/
General:
http://aumha.net - look under "Security" for various forums
http://rgharper.mvps.org/cleanit.htm
http://mvps.org/winhelp2002/unwanted.htm
http://www.aumha.org/a/parasite.htm - The Parasite Fight
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Malke
MS-MVP Windows User/Shell
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic"
Reply to Malke
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Pop-up problem
There are 853 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
