G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
Hi,
I hope I'm in the right forum! I have quite a few processes running on my
computer. I run AdAware and Spybot frequently but I was still concerned. I
Googled several of the processes and read that the file should only appear in
a specific folder; if it didn't it could be sypware, trojan, etc. When I
searched on my computer for the first few files, I found each file appeared
in several other folders besides the Windows/System32 folder. However, the
other folders the files are appearing in don't appear to be anything bad.
One is Windows/ServicePack Files and another is something like
Windows/Prefetch??? Should I be concerned about these other folders and if
so, can I just delete the extra files and that will take care of the problem?
I read about a program called Security Task Manager that is supposed to help
with these type issues. Anyone familiar with it and if it works? All help
would be greatly appreciated! Thanks!
Hi,
