G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
I have Radeon 9800 Pro 128Mb (Brand unknown) which I'm trying
to install an Arctic Cooling VGA Silencer onto. However, I'm
_really_ stuck.
According to the instructions, the barbs on the back of the board
for the original heatsink should be easy to squash enough so they
can be forced back through the holes in the boards. Not mine.
The barbs seem almost solid, so squeezing with a pliers has only
succeeded in mangling them without squashing them enough to fit
through the holes. I've tried to cut the bards, but can't get enough
leverage, and the plastic they're made from is pretty tough.
It's definitely not the heatsink itself that is stuck by adhesive,
as it now moves around quite a bit.
Please help
P.
_really_ stuck.
Please help
P.
