Archived from groups: alt.comp.periphs.videocards.ati (More info?)
What is the maximum resolution at which FSAA will work in the RADEON X
series cards? In the RADEON 9800 series it is 1600x1200. For HDTV
support I suspect that this number had to increase to at least 1920x1200.
Strangely, I don't find the number in the X800 data sheets on the ATI site.
Highest possible FSAA resolution depends on framebuffer footprint.
e.g. 1920 x 1200 x 4 (32-bit) x 2 (double-buffered) = 18.4 MB
Under 6x FSAA it swells to 111 MB, which doesn't fit on 128 MB cards because
of the other stuff like shader instructions and the Z-buffer that also share
the space. Thus, the drivers may have been hard-coded to limit AA to
1600x1200 under all modes.
"War is the continuation of politics by other means.
It can therefore be said that politics is war without
bloodshed while war is politics with bloodshed."
"CHANGE USERNAME TO westes" <DELETE_westes@earthbroadcast.com> wrote in
message newstWdndj4kqUJ5LTcRVn-tw@giganews.com...
site.
> Will
> westes AT earthbroadcast.com
