Dual monitor display problems
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Please help !!! This is crazy.
I installed a second graphics card. First one is ATI 8500 AIW. Second card
is Hightech Excalibur Radeon 9200 VIVO.
Both cards work fine, no problems with video or driver installation.
The problem is I cannot play any video. When I try to watch TV it gives me
"TV player failed to initialize the video." The video was working fine with
the 8500 before the 9200 was installed. With Media player, I can hear the
audio, but cannot see the video. With Intervideo's WinDVD it says, "I must
reduce the video size or resolution". All attempts to do this has failed.
I originally installed an NVIDIA pci card and the same thing happened. I was
told through the newsgroups that NVIDIA and ATI do not mix well together. So
I removed the NVIDIA and installed the Radeon card. And this did not work
either.
I really want this to work since the PCI card has dual output and I want to
use a third monitor. This is very frustrating.
Any help would be greatly appreciated.
Thanks, James.
5 answers Last reply
More about dual monitor display problems
  1. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    "Cellular Dealer" <quan(poop)elite(goaway)@hotmail.com> wrote in message
    news:osJXc.66612$UTP.40149@twister01.bloor.is.net.cable.rogers.com...
    with
    was
    So
    > either.
    Make you your mainboard chipset drivers are installed, that you have the
    lastest video drivers for you card and tuner, Direct X9 installed, and most
    importantly, the TV player is on your MAIN monitor and not the secondary
    one. Most TV cards won't play on the second monitor.
  2. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    Everything is up to date
    other programs like Win media player and windvd won't play either
    "Noozer" <dontspam@me.here> wrote in message
    news:8xNXc.234006$gE.183518@pd7tw3no...
    card
    me
    > with
    the
    must
    failed.
    > was
    together.
    > So
    work
    > > either.
    most
  3. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    news:VvPXc.4$5ZT.1@news04.bloor.is.net.cable.rogers.com:
    back up your important data, and do the reformat-and-reinstall XP dance.
  4. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    I suspect yer video player programs are detecting both screens on two
    cards as the actual desktop resolution. Try temporarily disabling one of
    the screens from the Control Panel display applet. As for the nVidia
    card, disable the third monitor from the display applet and try using
    the second and third screens in nView mode instead of Windows
    multi-monitor mode.The other thing you can try is turning the nVidia
    card into the primary display from Windows and using the Radeon as the
    secondary screen. See if that helps.
    > either.
    > Thanks, James.
  5. Archived from groups: alt.comp.periphs.videocards.ati (More info?)
    There are both ATi video cards currently. I have the Video working now. The
    TV tuner will not turn on. Keeps on saying that it fails to initialize.
    The only way it will work is if i physically remove the second card.
    "Sharanga Dayananda" <sharangad@hotmail.com> wrote in message
    news:aFsYc.125$H74.38@newsfe3-win.ntli.net...
    card
    me
    with
    the
    must
    failed.
    was
    together. So
    work
    > > either.
    to
    > > Thanks, James.
Radeon Dual Monitors Video ATI Graphics
