Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
I have noticed that after created a new local user account and added this
local account to the local Power Users Group it does not have the ability to
write to the root of C: unlink any other version of windows e.g. Win2000. Is
this by design. If so could you direct me to some MS Documentation.
Thanks
John
Sponsored Links
the set up of power users groups are explained by Microsoft as follows:
The Power User class can perform any task except for those reserved for
Administators. They are allowed to carry out functions that will not directly
affect the operating system or risk security. All domain accounts are part of
the Power Users group on public Windows 2000 computers.
Power Users Can:
Create local user accounts
Modify user accounts which they have created
Change user permissions on users, power users, and guests
Install and run applications that do not affect the operating system
Customize settings and resources on the Control Panel, such as Printers,
Date/Time, and Power Options
Do anything a User can
Power Users Cannot:
Access other users' data without permission
Delete or modify user accounts they did not create
I can'say that it'll answer yer question?
But I hop it helps???
Good luck..
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Local Power Users Group
There are 1389 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
