Catalyst Control Centre problem
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Can't get the CCC to run.
Net framework 1.1 installed OK, downloaded 4.9 with CCC and all
installed OK but when I click on the desktop icon nothing happens.
Tried accessing through Display setup and Start menu, still nothing.
Radeon 9700 Pro
XP Home - SP2
Has anyone else had this problem?
Thanks
Mark
"The arrow on a moving target,
the archer must be sure of his aim........"
N. Peart
In article <7ekbk0h2trc808mdi4st2ub34c7guuh6mi@4ax.com>, Mark Lepak
says...
> Radeon 9700 Pro
> XP Home - SP2
Yep. RE-installed and read the installation notes which said to
uninstall the old drivers.
Conor
Opinions personal, facts suspect.
>says...
>> Radeon 9700 Pro
>> XP Home - SP2
Did that, uninstalled using Cat Uninstaller.
Fresh install on 4.9 drivers.
Brgds
Mark
N. Peart
Sounds like it could be the problem with a firewall running. Allow CCC in
your firewall software.
mk38
"Mark Lepak" <Mark@recurve-bow.demon.co.uk> wrote in message
news:mkvbk0dcgjl48ltdhtd2cq5pks8tm2d31g@4ax.com...
> >says...
> >> Radeon 9700 Pro
> >> XP Home - SP2
> Brgds
> Mark
> N. Peart
Related ressources
news:7ekbk0h2trc808mdi4st2ub34c7guuh6mi@4ax.com...
> Radeon 9700 Pro
> XP Home - SP2
> Thanks
> Mark
I haven't had any trouble with the CCC but i've uninstalled it as to me it
just appears to be a bloated version of the display properties.
>mk38
Thanks, that worked kind of.
CCC now runs but I can't get access to the Direct 3D or OpenGL
screens, they just don't appear in the menu tree.
Mark
N. Peart
news:p e6dk0dp3jcn18bl2d6tru176feh01vodo@4ax.com...
>>mk38
This happened to me when I first installed this. I had to reinstall it AND
make sure the firewall accepted it during this process. Then the D3D and
OpenGL options appeared which weren't there initially. I ended up
uninstalling it anyway because I couldn't see the option for the 3D hotkeys
plus as others as said it's pretty bloated.
Ask the community
